cb360 carbs - Page 4
cb360 carbs
This is a discussion on cb360 carbs within the Technical forums, part of the Caferacer.net Forums category; its just a missing choke plate. whats the big deal. pull the choke totally out and see how it runs. it is possible that the ...
Results 31 to 37 of 37
Thread: cb360 carbs
  1. #31
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    its just a missing choke plate. whats the big deal. pull the choke totally out and see how it runs. it is possible that the screws are in the motor. sure. but probably not. more likely the linkage rod is stripped and the screws wouldnt go back in. pull ht eother plate out. see if that fixes it first.
  2. #32
    Mar 2002
    , , Turkey.
    oh, and thats an EASY fix.
  3. #33
    Senior Member Johnny Gaijin's Avatar
    Jun 2006
    seattle, washington, .
    yeah i'm not really worried about the choke plate anymore.
    it idles on one cylinder but runs on both when i get the rpm's up a bit.
    Senior Member Saml01's Avatar
    Aug 2009
    Brooklyn, NY, USA.
    What about once the engine warms up?
    Have you checked the plug gap?
    1974 Honda CB360
  6. #35
    Jun 2006
    even when warm it only idles (or often just dies) on one cylinder.
  7. #36
    Nov 2008
    You have primary and secondary main jets, what are the numbers on replacements?
    you did remove restrictor caps from mixture screw then remove screws?
    It really sounds like you need to clean carbs properly, may take multiple attempts as things work loose internally with use
    PJ
  8. #37
    Jun 2006
    i don't remember the numbers but i did check to make sure they matched.
  1. CB360 Carbs, Headers & Pods (yes, again)
    By Acemon in forum Technical
    Last Post: 04-15-2012, 11:21 AM
  2. CB360 - running! but smoking carbs.
    By Cursh in forum Technical
    Last Post: 02-07-2012, 11:50 AM
  3. cb360 carbs
    Last Post: 06-30-2011, 11:33 PM
  4. Wanted: CB360 Carbs
    By Saml01 in forum Wanted
    Last Post: 04-03-2010, 07:56 PM
  5. CB360 Carbs
    By Saml01 in forum Parts For Sale
    Last Post: 08-07-2009, 12:07 AM
cb360 carb cleaner
cb360 headers
cb360 valve job
cj360 stalls when warm
indian head shellac carburetor
