cb360 carbs
cb360 carbs
This is a discussion on cb360 carbs within the Technical forums, part of the Caferacer.net Forums category; the bike i bought two weeks ago wasn't idling well so i pulled off the carbs planning on cleaning them, maybe putting in new gaskets ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: cb360 carbs
    Senior Member Johnny Gaijin's Avatar
    Jun 2006
    seattle, washington, .
    cb360 carbs
    the bike i bought two weeks ago wasn't idling well so i pulled off the carbs planning on cleaning them, maybe putting in new gaskets or whatever. i didn't expect this:
    so now i need new carbs i guess.
    unless someone has that flap/panel thingy chilling on the shelf on some busted up carburetor that they'd want to sell me?
    assuming not... are cb350 carbs interchangeable with the 360s?
    also what do you guys think about this:
    http://cgi.ebay.com/ebaymotors/Mikun...Q5fAccessories
    not that i'd be really excited about putting in carbs that cost almost as much as the bike itself but if it was gonna improve performance and make things less of a hassle you could probably talk me into it.
    Nov 2008
    You should have already heard about SFL and their 'correct' jetting. (190~200 main jet )
    Pay a little extra and get carbs that will work from a CB350 specialist, the difference in engine capacity (326cc vs 356cc)wont make enough difference to notice.
    Decent ones rarely come up on eBay but a cheap set to rob parts out of should be pretty easy to find (or use and keep the ones you have for parts)
    you may have to 'bite the bullet' if you want them 'quick'
    350 carbs don't interchange with 360.
    PJ
    Nov 2008
    PJ
    A better question is where the missing parts are. Did the engine swallow one or both of the missing screws? I have seen them embedded in the piston crown or the head. That could be the cause of your poor running engine, too.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Jun 2006
    the bike does fine once you're going ten miles an hour, it's just below that that there's a problem, so i'm hoping the engine is ok. <profuse knocking on wood>
    different question:
    the big gasket you get in a carb rebuild kit:
    are you supposed to jam that into the float chamber? it looks too big...
    Feb 2009
    austin, texas, .
    i really dont know if i believe you when you say it runs fine past 10mph... thats a pretty gnarly carb prpblem. really strange too for both screws to be gone. i'd get some
    mikunis if you got some change to spend.
    honk if youre horny.
    Nov 2008
    Yep, the big 'O' ring is float bowl gasket.
    Get some Permatex Indian Head gasket shellac compound, its how Honda originally 'glued' them in (kinda sucks you have to buy 4oz for 5 spots per carb)
    Pilot jets/passages are probably still blocked
    It's too unusual for both screws to fall out, someone probably removed them to clean carbs (or thought it was a 'performance' mod?)
    PJ
    Senior Member Saml01's Avatar
    Aug 2009
    Brooklyn, NY, USA.
    I feel like an idiot for selling my stock carbs. For 35 years old, they were MINT. The guy that bought them slapped em on his bike and said it has never ran better. Now im stuck kicking myself in the ass trying to figure out those retarded mikuni carbs from the so called properly jetted kit SFL sells.
    1974 Honda CB360
    Jun 2006
    so correct me if i'm wrong because i really don't know much but...
    the flap that's missing is what flips when you use the choke, in the normal position it's wide open so the the flap is extraneous. if i'm not using the choke then it shouldn't be a problem... right? or do i have it backwards?
    SJW
    SJW is offline
    Senior Member SJW's Avatar
    Jul 2009
    Adanac, , Canada.
    Don't use the choke. You'll be fine.
    Just move somewhere warm.
    Canada, we\'re bigger and on top. If this were jail you\'d be our bitch.
  1. CB360 Carbs, Headers & Pods (yes, again)
    By Acemon in forum Technical
    Last Post: 04-15-2012, 11:21 AM
  2. CB360 - running! but smoking carbs.
    By Cursh in forum Technical
    Last Post: 02-07-2012, 11:50 AM
  3. cb360 carbs
    Last Post: 06-30-2011, 11:33 PM
  4. Wanted: CB360 Carbs
    By Saml01 in forum Wanted
    Last Post: 04-03-2010, 07:56 PM
  5. CB360 Carbs
    By Saml01 in forum Parts For Sale
    Last Post: 08-07-2009, 12:07 AM
cb360 carb cleaner
cb360 headers
cb360 valve job
cj360 stalls when warm
indian head shellac carburetor
