75' CL360 18" rim and hub fit my 70' CL350?
This is a discussion on 75' CL360 18" rim and hub fit my 70' CL350? within the Technical forums, part of the Caferacer.net Forums category; Subject pretty much says it all. I have a 1970 CL350 and am thinking about going from a 19" front wheel to an 18". Right ...
Results 1 to 5 of 5
    Junior Member Jackal's Avatar
    Sep 2009
    Seattle, Wa, USA.
    I have a 1970 CL350 and am thinking about going from a 19" front wheel to an 18". Right now on ebay there is a 18" off a 1975 CL360 with spokes and hub. I'm wondering if my drum brake assembly and axle would fit into the one off the 360.
    Anybody know?
    1970 CL350
    1971 CB350 (Mid frame up rebuild)
    Senior Member JackC's Avatar
    Oct 2006
    Oneonta, NY, USA.
    Does the CL 360 have a drum brake in the front? My '75 CB360 had a disc brake.
    May 2006
    Detroit-ish, MI, USA.
    Bolt-on replacement. Drum brake wheels/hubs are the same for both bikes. Spacers are the only thing that might be different.
    Senior Member Johnny Gaijin's Avatar
    Jun 2006
    seattle, washington, .
    yeah the '75 CL360 had a drum brake, the '75 CB360 had a disk.
    May 2006
    Incorrect. Disc brakes were optional on cb360, beginning with the first model year - 1974. That's what gives the multiple model designations, i.e. cb360, cb360t, cb360g - whatever they are. I can't say for sure about the cl360. That bike may have been equipped exclusively with the disc or with the drum, but I do know when it comes to cb360, both models (disc & drum) used the same forks, also shared by cb350 disc brake models. So... cb350 & cb360 drum brake models have interchangeable wheels, as do cb350/cb360 disc models, and all the above mentioned wheels play well with each other's forks, the only difference being spacers. In fact, all the above mentioned bikes can directly swap triples as well.
  1. 1975 cl360
    By colt881969 in forum Technical
    Last Post: 10-19-2011, 10:09 PM
  2. Mikuni's on my CL360
    By Hamburg in forum Technical
    Last Post: 09-27-2008, 10:14 AM
  3. CL360 Cam
    By Pete Casper in forum Technical
    Last Post: 06-11-2008, 01:28 PM
  4. cl360 gp shifting
    By eviltwin in forum Technical
    Last Post: 01-11-2008, 03:11 PM
  5. 75 CL360 4 Sale
    By Anythingillegal in forum Bikes For Sale
    Last Post: 04-30-2007, 10:06 AM
are cb350 and cb360 front wheels interchangable
