'73 H1-D kawa carb. starter jet size?
This is a discussion on '73 H1-D kawa carb. starter jet size? within the Technical forums, part of the Caferacer.net Forums category; Carbs are Mikuni VM28SC ; they were so clogged up with crap,I resorted to using a small drill bit to clear the bowl-to-starter plunger fuel ...
Results 1 to 5 of 5
    Junior Member koob's Avatar
    Sep 2009
    , Saskatchewan, Canada.
    Carbs are Mikuni VM28SC ; they were so clogged up with crap,I resorted to using a small drill bit to clear the bowl-to-starter plunger fuel galley,they blow freely now but I've sadly found out there was a jet in that passage that's most likely oversize now. What I want to do is make brass plugs (yeah, I did all three before realizing my mistake) with the proper sized jet hole & press or thread them into the fuel inlet holes for the starter circuit visible from the float side in the bottom of the float bowl. Can anybody tell me what the diameter of the starter jet is for this carb?
    Senior Member chetriply's Avatar
    Nov 2006
    Springfield, MO
    Try kzrider.com. Those guys know everything Kawasaki.
    \"I have many leather-bound books and my apartment smells of rich mahogany.\"http://www.hogsbreathcycles.com/
    vm28s would not be the stock size for an H1D (I think those are 26mm carbs stock). Sudco can sell you any jet you need but since you are in custom territory it is hard to say what the stock size was.
    Sep 2009
    No . 28's were used '69-'76 , Sudco doesn't list or show starter jets. I've got this question in a few forums, but nobody seems to have the time to measure one.
    Sep 2009
  1. Best size Mikuni carb for stock CB350? 28 maybe?
    By whiskeysid in forum Technical
    Last Post: 10-25-2012, 07:43 PM
  2. 72 suzuki t350 carb size
    By kbabb06 in forum Technical
    Last Post: 05-24-2012, 11:38 AM
  3. Yamaha DT250 stock carb size
    By whiskeysid in forum General
    Last Post: 03-29-2009, 10:20 AM
  4. need help to pick out the right carb size
    By jaguar in forum Technical
    Last Post: 03-28-2007, 08:21 PM
  5. Anyone know the carb size......
    By Swagger in forum Technical
    Last Post: 09-05-2006, 04:12 PM
