Checking compression: Kick start vs. Electric
This is a discussion on Checking compression: Kick start vs. Electric within the Technical forums, part of the Caferacer.net Forums category; I've searched the forum and can't find anything. This past weekend I checked the compression on my '75 CB360. Since my bike is partially disassembled ...
Results 1 to 10 of 14
    Junior Member shidifen's Avatar
    Dec 2009
    Lexington, KY, USA.
    This past weekend I checked the compression on my '75 CB360. Since my bike is partially disassembled I didn't have the battery. So to check the compression I just kicked the bike over 4-5 times. I got 100psi from both cylinders.
    I was talking to some buddies at work about the compression because I'm not sure if 100psi is good or not. They felt that if I had used the electric start I would have seen a higher compression reading.
    Does this make sense? I would have thought that the compression would be the same regardless how fast the motor was turning over. Provided you have a good seal between the piston and the cylinder aren't you just compressing air (air fuel mixture) independent of speed?
    Many thanks,
    Stephen
    shidifen
    1975 Honda CB360T
    Senior Member JackC's Avatar
    Oct 2006
    Oneonta, NY, USA.
    Be sure that the chokes are open on both carbs, and that the throttle is held wide open when you kick it over. Kick it until the reading goes no higher.
    Sep 2008
    Rochester, New York, USA.
    make sure you take the spark plugs out too, it might give a more accurate reading if you just take the carbs off, as the vacuum slide may not be rising at all on kick start, 100psi is pretty low for that bike though, but make sure you're not causing resistance somewhere before tearing the thing apart
    Take the spark plugs out to check compression? I'd assume you screw the compression tester into the sparkplug hole. What effect would removing the other sparkplug have on compression? But what camshaft do you have on this bike? Is this static or dynamic or effective compression?
    Craig
    why are you checking the compression cold? Air cooled motors have loose tolerances and really you should be checking this with the engine up to operating temp. Checking cold really all you want to see is that there is not a huge difference between the two.
    , Decrepit and Decomposing, .
    Do ya reckon air cooled engines have more ring gap per inch of bore than water cooled engines?
    Yes
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    How much is that?
    Skirt clearance.... plenty of air cooled engines run a half thou.
    I think a new hd runs a thou and a half on the skirts, right out of the box.
    Stem to guide... same.
    Btw.. kick or electric should give the same valid numbers
    How much is that?
    How much is that?
    I would say 6 +/- 2
    Plenty cold seize where the studs distort the bore and plenty run more.
    I think Briggs and Stratton runs 3.5 on the skirts, right out of the box.
    Not on a Briggs.
    P.S. I might have made my numbers up.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  1. kick start only
    By shane2007 in forum Project Builds
    Last Post: 12-23-2012, 09:20 AM
  2. Kick start is just so much cooler
    By RJB in forum General
    Last Post: 11-25-2011, 12:57 PM
  3. 1971 yamaha 200 electric start
    By 71yammy in forum General
    Last Post: 08-01-2010, 08:04 PM
  4. Kick Start Reliability
    By ZouLou in forum Technical
    Last Post: 12-11-2008, 08:20 AM
  5. Ditch the electric start?
    By 75SevenFityFo in forum Technical
    Last Post: 06-15-2008, 11:19 AM
cb360 compression cold
