brake modification questions - Page 2
This is a discussion on brake modification questions within the Technical forums, part of the Caferacer.net Forums category; [quote]quote: Originally posted by Victor52b Originally posted by txchainsawgogi Asbestos won't be an issue if you don't breathe while doing it. this is only true ...
Results 11 to 20 of 25
  1. #11
    Sep 2008
    , , Mongolia.
    [quote]quote:Originally posted by Victor52b
    this is only true inasmuch as it is an impossibility. it is equally impossible to not breathe while sanding as it is to not suffer from contact with asbestos.
  2. #12
    May 2006
    Detroit-ish, MI, USA.
    Asbestos is only a problem when fryable (airborne particulate). Common in asbestos removal is keeping it wet. Perhaps you could sand pads while wet, keeping the particulate from becoming airborne. I'm not recommending it, but I do know asbestos is still in use today, in applications where airborne particles are not an issue. It's a tricky question, but there's a fair bit of controversy regarding health risks of asbestos. I wouldn't do it myself (sand down brake pads) but I have 3 small ones running around my house. To find a compatible rotor seems a safer & more elegant solution.
  3. #13
    Feb 2009
    austin, texas, .
    i could wet sand these outdoors, with the pads and belt sander in a box...with clear plastic over the top and only my gloved hands pokin' through. i could even wear a gas mask during it.
    thats the quick solution.
    im also going to call around to see if meineke- type brake shops are even willing to touch a motorcycle rotor.
    honk if youre horny.
    Aug 2006
    Portland, Oregon, USA.
    Take the rotor to a machine shop with a surface grinder.
    Take nothing to knock off as much or as little as you want...
    ~Albert Einstein
  6. #15
    Senior Member sdurand76's Avatar
    Jan 2009
    Montreal, Quebec, Canada.
    most older shops will have a small bench lathe specifically for doing rotors and drums for 'trueing them ... I would suspect most name brand places push the 'just replace it' motif
  7. #16
    Feb 2009
    austin, texas, .
    thats the trouble with this town, we dont have any older shops that im aware of. its all big name guys. hopefully an austin member will see this post and correct me!
  8. #17
    Senior Member Victor52b's Avatar
    Feb 2009
    Eastford, CT, Sri Lanka.
    friable?
  9. #18
    Feb 2009
    austin, texas, .
    friable?
    *delicious
  10. #19
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    being the first to do it to others, i love it when people call him out on shit!
    however, in his defense, he humbly stands corrected when it's due. dude's got integrity. still wears women's shoes though.
    iphone generated fag
  11. #20
    Nov 2008
    Asbestos was outlawed in US in late 1980's,(I think around 1986?)
    Unless you have real early brake pads they will have something else in there(bronze, Kevlar, etc)
    I still wouldn't go breathing the dust though
    It's not a good idea to widen caliper, why don't you re-dill rotor?
    (admittedly it looks shite but you could make a cover plate to hide extra holes)
    PJ
  1. Frame modification Signatories
    By 88kiwi in forum Technical
    Last Post: 04-16-2012, 07:08 PM
  2. Questions about cb200 front brake
    By fox8991 in forum Technical
    Last Post: 09-10-2010, 03:44 AM
  3. Fuel tank modification pic.
    By OC Steve in forum General
    Last Post: 08-09-2010, 10:31 AM
  4. Wiring a brake switch to the front brake
    By cafe350 in forum Technical
    Last Post: 09-07-2009, 08:46 AM
  5. Replies: 11
    Last Post: 06-27-2008, 08:50 AM
cb200 front brake
