brake modification questions
This is a discussion on brake modification questions within the Technical forums, part of the Caferacer.net Forums category; what are my options if the new dual piston caliper i got off ebay is a bit too narrow for my super thick cb 350 ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Feb 2009
    austin, texas, .
    what are my options if the new dual piston caliper i got off ebay is a bit too narrow for my super thick cb 350 rotor??
    do they make thinner rotors for different years? its a four bolt pattern 75' cb 350 wheel.
    is there a safe way of widening the caliper halves?
    ...or can i run the brake pads through a planer/belt sander without glazing them?
    or are those all dumb questions?
    honk if youre horny.
    SJW
    SJW is offline
    Senior Member SJW's Avatar
    Jul 2009
    Adanac, , Canada.
    Can't you just get your rotor turned down a bit?
    Canada, we\'re bigger and on top. If this were jail you\'d be our bitch.
    Feb 2009
    austin, texas, .
    i dont know of any shops that do that...i suppose it would be the easiest thing to do though.
    May 2006
    Detroit-ish, MI, USA.
    No such thing as a '75 cb350. Not in America, anyway. CB350 was replaced in 1974 by cb360. But it used the same front wheel as the '73 cb350.
    Feb 2009
    austin, texas, .
    could be a 360 wheel. im just goin off of what was written on it when i bought it.
    Whickh caliper do you have? If it takes the EBC FA-69, that was available in several thicknesses to accommodate differing disc thicknesses. Otherwise, using thinner used pads should work, too.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Feb 2009
    austin, texas, .
    the caliper is off a 78' cb400t, and the rotor off that model would have worked but it was a five bolt pattern, and the new wheel im using is a four bolt rotor.
    Feb 2009
    austin, texas, .
    so can i take it to a car brake shop that does rotors? or do you think they'd tell me to go away haha.
    is belt sanding the pads for now a terrible idea?
    Mar 2004
    Raymond, NH, USA.
    Depends. Do you like asbestos?
    Senior Member Victor52b's Avatar
    Feb 2009
    Eastford, CT, Sri Lanka.
    How much are you talking about? A little bit shouldn't be a problem (a mm or so) if you keep them parallel.
    Asbestos won't be an issue if you don't breathe while doing it.
  1. Frame modification Signatories
    By 88kiwi in forum Technical
    Last Post: 04-16-2012, 06:08 PM
  2. Questions about cb200 front brake
    By fox8991 in forum Technical
    Last Post: 09-10-2010, 02:44 AM
  3. Fuel tank modification pic.
    By OC Steve in forum General
    Last Post: 08-09-2010, 09:31 AM
  4. Wiring a brake switch to the front brake
    By cafe350 in forum Technical
    Last Post: 09-07-2009, 07:46 AM
  5. Replies: 11
    Last Post: 06-27-2008, 07:50 AM
cb200 front brake
