CB360 rear brake arm?
This is a discussion on CB360 rear brake arm? within the Technical forums, part of the Caferacer.net Forums category; In theory (or in reality) would it make any difference if the rear brake arm was rotated 180 degrees? I want to turn the arm ...
Results 1 to 3 of 3
    Senior Member Victor52b's Avatar
    Feb 2009
    Eastford, CT, Sri Lanka.
    In theory (or in reality) would it make any difference if the rear brake arm was rotated 180 degrees? I want to turn the arm 180 degrees so it will pull from the top instead of the bottom. It makes a rear set pedal easier to fit.
    Would it matter which way the cam opens the shoes?
    I don't think so, but I've been wrong before.
    Nov 2008
    slight difference in leverage on leading shoe
    PJ
    Feb 2009
    Thanks PJ. I figured something like 2 or 3 percent.
    I'm used to BSAs and Triumphs so I shouldn't notice.
  1. Redesigned Rear Brake
    By Acemon in forum General
    Last Post: 05-18-2012, 01:52 PM
  2. CB360 Rear Wheel
    By chetriply in forum Wanted
    Last Post: 10-07-2008, 02:57 PM
  3. cb160 rear hub/ brake
    By ROSKO in forum Wanted
    Last Post: 01-19-2008, 02:45 PM
  4. Rear brake caliper
    By lefty337 in forum Wanted
    Last Post: 07-29-2007, 11:34 PM
  5. 750 rear brake hub on 550?
    By del105 in forum Technical
    Last Post: 06-23-2007, 11:30 AM
