cb750 k8 carb question
This is a discussion on cb750 k8 carb question within the Technical forums, part of the Caferacer.net Forums category; I have a 1978 cb 750 with the k8 carbs (that have the accelerator pump). I pulled them off over the fall and forgot what ...
Results 1 to 10 of 12
    Junior Member tsr4's Avatar
    Mar 2010
    Portland, Oregon, USA.
    I have a 1978 cb 750 with the k8 carbs (that have the accelerator pump). I pulled them off over the fall and forgot what the extra tubing and inlet is for? take a look at carb number 2. I have connected in top picture the main fuel line, then to the left of it is a fuel line spot? or is it a blow off of some sort? The bottom picture shows them both hooked up... help a noob out!
    \"thou art a boil, a plague sore\" W.S.
    Mar 2010
    oh, yes I almost forgot... after looking at the clymer and the workshop manual, none of them seem to have this extra line going into #2 carb... just the fuel line from the fuel tank.
    my first thought was that it was vacuum, esp since #2 is the carb with the accelerator pump. it isn't barbed so it doesn't look like it is meant to have a hose on it.
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    +1
    iphone generated fag
    Senior Member oneworden's Avatar
    Jul 2008
    franklin, WI, USA.
    I just looked up the carbs on babbittsonline.com and the hose that connects to it is called an air vent tube. Looks like a tube just slides on and runs down with the other draing hoses.
    Did you hear about the pirate with two wooden legs?
    They caught fire and burned his ass to the ground!
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    I know this is an old thread, but isn't that the float bowl vent hose? It can be left open as long as there's no way water or dust is getting into the float bowl. I'd recommend fitting a hose .
    Mar 2010
    , IL, .
    Junior Member jaggedtimelapse's Avatar
    Oct 2016
    Quote Originally Posted by Teazer View Post
    Is the above post true? I have a 78' cb750k and I recently took the gas tank off to clean the rust from the inside and now I'm not sure where or if this hose connects to anything. Although it is connected to the second carb like the OP photo. The smaller hose. the I'm a total noob so any help would be much appreciated. Can't find any other info about it. Seems like the manual doesn't specify either.
    I've attached a photo. Hopefully this is good enough to identify.
    If it is just a vent tube...can I just pull it through and route it underneath the seat next to the battery or something?
    Thanks in advance.
    I am much less familar with the 78 carbs, but on the earlier ones they are between carb #2 and #3, yes they have two vent hoses attached that keep crap from coming in and clogging the vent.
    There is also a fuel tank vent that attaches to a plastic fitting and hose that runs near the battery box.
    it could be either of those.
    Oct 2016
    Thanks for your response!
    The plastic fuel hose that runs near the batter box Is still connected. In theory, it should be the one that I circled from the op's photo. If I'm not mistaken the other hose (not circled) connects to the petcock right? If it is THAT vent hose (circled), does it just route to the atmosphere and do you know the best place to run it?
    Thanks for your help man! it's much appreciated.
  1. FCR carb question
    By tsflstb in forum Technical
    Last Post: 07-03-2010, 02:04 AM
  2. Honda cb750 Dohc Carb question
    By Ferroman in forum Technical
    Last Post: 12-28-2008, 02:09 PM
  3. Carb question
    By Pete Casper in forum Technical
    Last Post: 03-31-2008, 08:02 AM
  4. Carb question
    By bam42685 in forum Technical
    Last Post: 09-25-2007, 08:56 AM
  5. Carb question.
    By Fatguylittlebike in forum Technical
    Last Post: 03-29-2007, 01:46 AM
1978 cb750 carb vacuum hoses
1978 cb750 carburetor vacuum hose attachment
1978 cb750 carburetor vent
1978 cb750k8 carburetor
cb750 carb fuel accelerator pump
cb750 k8 carburetor
honda cb750 carburetor fuel lines
what are 2 hoses cb750 carb
