Fork Brace
Fork Brace
This is a discussion on Fork Brace within the Technical forums, part of the Caferacer.net Forums category; So I've put in new all balls steering head bearings and front wheel is true but I stillhave a little wobble in front end my ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Fork Brace
    Member Rwalker004's Avatar
    Mar 2010
    Chaska, MN, USA.
    Fork Brace
    So I've put in new all balls steering head bearings and front wheel is true but I stillhave a little wobble in front end my tires are also new and balanced. I've read threads about fork braces and I believe I have 33mm stock forks but I can't seem to find a fork brace that will work. If any knows some more info on this please chime in thanks again to all members in this forum with out your help I'd be almost lost.
    Junior Member oldTS's Avatar
    Oct 2007
    Central, WI, USA.
    Do you proper air preasure in the tires?
    Senior Member midge's Avatar
    Nov 2007
    , , USA.
    what bike???
    put the front fender back on
    Mar 2010
    Chaska, MN, USA.
    Fender is on. air is to spec Avon road raiders
    Mar 2010
    Chaska, MN, USA.
    It's a 1972 cb350
    Feb 2006
    Fork tubes even in the triple clamps? Everything slides together nicely? Not tweaked from prior crash.
    Wheel bearings?
    Serviced the forks lately?
    Then looky at the rear wheel alignment, swingarm bearings, rear tire balance, shocks. Maybe the wobble's really at the rear, but you're confused.
    This'll start an argument:
    Unless everything else is right and tight you're more likey to cause a wobble w/a forkbrace than fix one. IMO
    Mar 2010
    Chaska, MN, USA.
    Maybe it's the triple tree I don't know alot about it's history it was basicly a barn bike until I fixed it up. The rear is all good new shocks bronze bushings new barrings in both wheels new bushings and shocks made a huge differance in the rear. The bike would be amazing if it wasn't for the slight wobble in front. Oh and I drained Fork fluid and replaced seals in it also.
    Nov 2008
    Wheel wobble at what speed?
    If tyres and wheels don't have excessive run out, correct tyre pressure (or a few pounds more) and, are correctly balanced, weak forks will cause weave not wheel wobble.
    Direction change will be very slow because gyroscopic effect wants wheel to go in straight line, fork brace helps for that.
    Tyre pressure and tread pattern can cause 'patter' at higher speeds but not usually below 80mph
    Mar 2010
    Chaska, MN, USA.
    wobbles at about 65 worse at 75mph but i also notice when turning it higher speeds it has a tendency to struggle sticking with turn and wants to move towards center lines if that makes sense?
    what tires?
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
  1. New Fork Brace
    By tylermoney in forum General
    Last Post: 09-30-2011, 03:12 PM
  2. Fork brace
    By YucA in forum Technical
    Last Post: 02-15-2011, 11:08 AM
  3. Fork Brace
    By Whitehurst in forum Parts For Sale
    Last Post: 01-08-2009, 12:47 AM
  4. fork brace
    By 72CafeRacer in forum Technical
    Last Post: 06-26-2008, 06:28 PM
  5. Fork Brace
    By xkillerbx in forum Technical
    Last Post: 05-02-2008, 12:23 PM
33 mm fork brace
33mm fork brace
cafe racer motorcycle fork brace
fork brace 33mm
