Mikuni VM32 manifold for 1965 CB450?
This is a discussion on Mikuni VM32 manifold for 1965 CB450? within the Technical forums, part of the Caferacer.net Forums category; Hello folks. I'm looking for some carb manifolds (insulators) for my 1965 CB450. The stock manifolds were made to attach to the original Keihin's that ...
Junior Member
Hello folks. I'm looking for some carb manifolds (insulators) for my 1965 CB450. The stock manifolds were made to attach to the original Keihin's that had a spigot diameter of approximately 43mm. The Mikuni's spigot diameter is 40mm. The CB450's bolt holes for mounting the carb manifolds are approximately 64mm apart, whereas the only SUDCO Mikuni manifolds (flanges) with a 40mm spigot diameter either have a 60mm or 75mm mounting bolt hole diameter. Does anyone know where I can get some Mikuni VM32 manifolds for my CB450? Oh, and it would be a bonus if they were angled like the 350 manifolds (the battery box is not removable and it is tight in there). Thanks!
David
Senior Member
I'm just going through this same issue with a mikuni installation on one of my bikes - Sudco makes different size manifolds with various spigot openings and diameters. They even have angled manifolds. Take your carb parts down to your local bike dealer, they should be able to match up your requirements in their parts unlimited book. Your might even be able to use your current manifold as a clamp should make up 3mm with no problem.
Bob - Palmyra NY
2 - 69 CB750, 1 Turbo
1 - 71 CB750
Junior Member
I just talked to SUDCO tech support (Chad). He said they don't make a manifold to fit the 1965 CB450, but that they recommend using the stock manifold and "stuffing it in there". When I pointed out that the bead in the stock manifold and the groove on the mikuni spigot aren't even close to lining up, he recommended "milling down the spigot". Well, I can't do that...nor do I want to, just in case I need to return them. He didn't have any other ideas...nor did he seem to care [}
]. I found a website in the UK with a manifold that looks like it might be really close:
http://www.allensperformance.co.uk/p...manifolds.html
It's the PM15 listed for an RG500 and VM34. The C dimension (35.5) on my stock manifold is 32mm, so I'm not sure if that step down going into the head will cause problems, and the A dimension (63) on my stock manifold is 64mm, close enough to buy and try, I guess. The PM14 listed for a TR500 and VM34 comes close, too, if it weren't for the 8.10 bolts (mine are 6). Interestingly, The PM16, listed for the CB450 (and the VM36!) is way off (except for the 65mm "GP centers"?). Maybe it's for a late model CB450. *sigh*
Seems strange that such a thing isn't easier to find.
Junior Member
Hey buddy... found that: http://www.bikebandit.com/mikuni-mounting-flange
Check the 62mm mine is around 63.
See you around!
Junior Member
See you around!
- You may not post replies
- You may not edit your posts
Forum Rules
By txchainsawgogi in forum Technical
Last Post: 05-29-2012, 08:04 PM
By manchildburns in forum Parts For Sale
Last Post: 10-07-2010, 09:50 PM
By joevirus563 in forum Technical
Last Post: 06-11-2010, 09:13 AM
By snorkelfork in forum Parts For Sale
Last Post: 02-26-2009, 11:36 AM
By 736cafe in forum Vintage Motorcycle Racing
Last Post: 01-24-2009, 02:43 PM
62 mm to carb flange mikuni
75mm cb450
cb450 carburetor mount
cb450 mikuni or keihin
how do i install mikuni carbs on a cb450
mikuni carb cb450
mikuni carb cb450 install
mikuni flange 62mm
vm32 on cb450 manifold
