VM32 cb450 71 jetting + intake manifold
This is a discussion on VM32 cb450 71 jetting + intake manifold within the Technical forums, part of the Caferacer.net Forums category; Hi everyone. I'm working on my cb450 71 cafe racer project. Here's my setup: 2-2 Almost straight muffler Pod air filder Head ported and polished ...
Results 1 to 10 of 10
    Junior Member joevirus563's Avatar
    Jun 2010
    Laval, Quebec, Canada.
    Hi everyone.
    Here's my setup:
    Pod air filder
    I was planning to buy a set of Mikuni VM32 but I was wondering if someone her already have them on cb450 and what is the actual jetting that you're using?!?
    Thanks!!!
    BTW anywhere to find intake manifold for cb450 71? I know someone post it for a 65 but what about 71? Someone got an idea?
    Thanks.
    Jun 2010
    So? anyone?
    Junior Member davidw's Avatar
    May 2010
    San Clemente, California, USA.
    So far, the best selection of manifolds I have found online are at:
    http://www.allensperformance.co.uk/p...manifolds.html
    There isn't a perfect one there for my application, and I still have an email to them unanswered about costs, but that's as far as I've gotten on the subject.
    Good luck!
    Jun 2010
    Good luck!
    Ok have you ordered one yet? Can I use the stock one?
    May 2010
    Good luck!
    I have not ordered one, yet. Like I said above, I'm still waiting to hear back from them about costs.
    As far as using the stock one, I am not able to use my stock manifold. I'm not sure if you can, though. My manifold is just too different from the mikuni for me to feel good about using it. As long as allensperformance.com.uk is reasonable with it's prices (shipping from the UK might not make it worth it), I'll buy and try one of theirs. I'll let you know how it goes if I do.
    Jun 2010
    I found some mikuni manifold at jcwitney.!! I'll drill some other hole for the screw as the bolt pattern is not right... a few mm off. As for your jetting? Are you jet correctly yet?
    May 2010
    The bolt hole dimension is 5 mm off for my application...and that's the *only* dimension they give! No thanks.
    My mikunis came pre-jetted for street use from Buff Harsh. With no workable flange, I haven't put them on yet.
    May 2010
    Jun 2010
    Your size is 63mm between spoke?
    Jun 2010
  1. mikuni vm32 jetting for 400cc
    By txchainsawgogi in forum Technical
    Last Post: 05-29-2012, 08:04 PM
  2. CB450 Weber Manifold
    By the skunk in forum Wanted
    Last Post: 06-27-2011, 06:45 PM
  3. Jetting VM32 on stock CB350 engine
    By manchildburns in forum Technical
    Last Post: 10-25-2010, 09:59 AM
  4. Mikuni VM32 manifold for 1965 CB450?
    By davidw in forum Technical
    Last Post: 06-14-2010, 11:21 AM
  5. mikuni vm32 to keihin cv intake manifolds?
    Last Post: 01-06-2010, 06:34 PM
2 to 1 intake cb450
cb450 2 into 1 intake manifold
cb450 carb manifold
cb450 intake manifold measurement
cb450 vm32 carb settings
mikuni cb450 horsepower
rejetting 71 cb450
vm32 intake manifold
what is the best jetting for a cb450
