CB450 fork spacing info needed
This is a discussion on CB450 fork spacing info needed within the Technical forums, part of the Caferacer.net Forums category; attempting to put a 19" cb450 front whell on a cb400. first thing i need to know to decide if i go further than having ...
Results 1 to 5 of 5
    Member chelpdogg's Avatar
    Jun 2010
    Brisbane, Queensland, Australia.
    first thing i need to know to decide if i go further than having a rebuilt wheel and shiny new spokes on it is how far apart are the fork tubes? and also where the axle goes thru the bottom of the forks what is the distance apart from L to R there too? gotta fins out if i've got enough room between my 400 forks for the hub and speedo drive of a 450 wire spoked wheel. hoping i haven't jumped in blind with no chance of it happening
    That\'d be a good idea if it made any sense
    Jun 2010
    pretty sure the wheel is from like 71 or 72 maybe.. I don;t know enough about them to be certain.
    Jun 2010
    Jun 2010
    on second thoughts since i don't have the speedo drive unit for the wheel as yet. if someone could measure the wheel thickness(excluding any spacers) including the speedo drive unit at the front axle that'd be a great start for me.
    cheers.
    Jun 2010
    cheers.
  1. Over Flow Bottle info needed
    By JackC in forum Technical
    Last Post: 08-02-2011, 06:08 AM
  2. Welding info needed
    By rich46 in forum Technical
    Last Post: 01-22-2011, 03:48 PM
  3. fork and wheel swap info
    By Alan F. in forum Technical
    Last Post: 10-24-2009, 04:24 PM
  4. shop manual info needed
    Last Post: 07-26-2009, 07:51 PM
  5. CALLING TYLER - RD400 Info Needed
    By ZouLou in forum Technical
    Last Post: 11-18-2008, 03:07 AM
cb450 fork spacing
