CB350 Bronze Swing-Arm Bushing Sets??????
This is a discussion on CB350 Bronze Swing-Arm Bushing Sets?????? within the Technical forums, part of the Caferacer.net Forums category; Is anyone still having these made up? Or putting an order together for them to be made up? Nick....
Results 1 to 2 of 2
    Senior Member nic579's Avatar
    May 2010
    Nick.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Isn't there a suitable needle roller bearing available - say a pair of HK2220 each side or 2020 depending on the size. Just cut off the last 2 or 3mm of the end of stock bushes so you have a thrust flange and throw away the rest. Easier and cheaper than bronze bushes.
  1. CB175 Swing Arm Bushing - Alternative to OEM
    By theboxrules in forum Technical
    Last Post: 10-11-2011, 10:34 PM
  2. honda cb350 bronze bushing, good price???
    By kochic in forum Technical
    Last Post: 04-25-2011, 06:21 PM
  3. Reworking CB350 Swing Arm Support[Another Q?]
    By boomshakalaka in forum Technical
    Last Post: 11-16-2009, 01:58 PM
  4. Replies: 0
    Last Post: 07-20-2009, 05:20 PM
  5. shocks/swing arm for a cb350
    By Eric750 in forum General
    Last Post: 04-10-2006, 06:51 AM
1971 honda cb175 swingarm bushing
cb 350 bushing dimensions
cb350 bronze swing arm bushings
cb350 swingarm bushings
cb350f swing arm bushing
cb350f swingarm bushings
honda cb350 swing arm bushing
honda cb350 swingarm bushing dimensions
honda cb350 swingarm bushings
