CB350 questions
CB350 questions
This is a discussion on CB350 questions within the Technical forums, part of the Caferacer.net Forums category; im trying to get my 71 up and running sat for a few years. the gearbox is very tight and hard to find neutral. is ...
Results 1 to 4 of 4
Thread: CB350 questions
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    CB350 questions
    the gearbox is very tight and hard to find neutral. is that normal on a motor that sat? (ive never had it and all my other bikes have sat)
    my friend has a 350 that sat and it feels the same way[?]
    i cleaned out the carbs and she idles great and off idles is fine but at 6k it falls on its face. sometimes it will power through but most times it will not.
    in 5th at 50mph it feels like its cutting/hunting
    they are stock carbs with stock airboxes.
    fresh fuel
    good plugs
    im going to try and time it and clean the carbs again and see if that helps
    was wondering if anyone had run into this or had a trick
    thanks
    I am Derby\'s Bitch
    Dec 2005
    Albany NY
    also what is base line tunning for the needles?
    I am Derby\'s Bitch
    Dec 2005
    Albany NY
    I am Derby\'s Bitch
    Sep 2010
    Boston, Georgia, USA.
    dont know anything about the needles, but my '72 wouldnt rev past 5 or 6k when i got it because it was only firing on one cylinder. set point gap and make sure you are getting fire to the plugs.
  1. Ballpark questions for a CB350
    By DemonicCow9852 in forum Technical
    Last Post: 12-05-2012, 03:42 PM
  2. CB350 Racer Build questions
    By Ron Bloker in forum Vintage Motorcycle Racing
    Last Post: 08-31-2012, 04:45 PM
  3. CB350 race build questions
    By Livetoskate in forum Vintage Motorcycle Racing
    Last Post: 08-21-2012, 05:59 PM
  4. CB350 Performance Questions
    By freeskier in forum Technical
    Last Post: 10-25-2011, 08:34 PM
  5. 2 questions about a cb350
    By Tim in forum Technical
    Last Post: 06-17-2009, 07:49 PM
cb350 points gap
how to set point gaps on cb350
