Model Year Question - CB360
This is a discussion on Model Year Question - CB360 within the Technical forums, part of the Caferacer.net Forums category; I have a CB360 that is stamped with a birth date of 9/74. Does this make it s '74 model or a '75? Any help ...
Results 1 to 6 of 6
    Member mega4ce's Avatar
    Nov 2010
    Los Angeles, CA, USA.
    I have a CB360 that is stamped with a birth date of 9/74. Does this make it s '74 model or a '75? Any help would be appreciated.
    Damn, I thought that would work...
    Fairfax, VA, USA.
    Nov 2010
    So I'm still trying to figure out what model/year I have as my serial number reads CB360E-20XXXXX. No models on that site correspond with the sequence. Any other ideas?
    Nov 2010
    I'm going to assume its a '75 360t. I was searching the serial numbers on http://auction.netbikes.com.au/vjmw....page=350-450cc and couldn't find any thing that reads exactly as mine but between the two sites I guessing its a '75t. The colors match up and it has a front disc.
    actually the 1975 models on that site correspond to your vin. You just didn't read far enough down:
    1975 CB360T0
    CB360T0
    1974 CB360T0
    * Colors:
    o Candy Riviera Blue Metallic
    o Light Ruby Red
    * The gas tank stripes were black and white
    * The "CB360T" side cover emblem was white and yellow
    * The breaker points cover was black
    * The front brake was a hydraulic disc
    * The engine was a 356cc OHC parallel twin linked to a 6-speed transmission
    * The serial number began CB360T-2000001.
    Nov 2010
    Great. Thanks for the help.
  1. cb360 -> cb550/650 forks question
    By kerosene in forum Technical
    Last Post: 06-05-2011, 11:30 PM
  2. cb360 wheel Question
    By hexcb360 in forum Technical
    Last Post: 04-29-2011, 10:05 PM
  3. Honda CB360 Carb question
    By shidifen in forum Technical
    Last Post: 12-31-2009, 02:25 PM
  4. seat mod question cb360
    By jimmyxdiego in forum Technical
    Last Post: 11-19-2007, 10:06 PM
  5. Speedo question...what year is it?
    By Zeke in forum Technical
    Last Post: 02-17-2006, 06:37 PM
74 cb360 engine serial numbers
cb360 engine numbers
cb360 engine serial number years
cb360e
cb360e cafe racer
cb360t year model
honda cb360 serial number
serial numbers for honda cb360
what year is cb360e
