Screwed
Screwed
This is a discussion on Screwed within the Technical forums, part of the Caferacer.net Forums category; So far i have tried to get this screw on my alternator cover out using and easy-out, a spiral extractor (which snapped off inside where ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Screwed
    Member mega4ce's Avatar
    Nov 2010
    Los Angeles, CA, USA.
    Screwed
    So far i have tried to get this screw on my alternator cover out using and easy-out, a spiral extractor (which snapped off inside where i had drilled), and an impact driver. It is soaked in a lubricant to try and break down whatever is seizing it. Any other thought as to what I can do to break it free, other then to drill it out and retap the hole with a larger screw?
    Damn, I thought that would work...
    May 2006
    Detroit-ish, MI, USA.
    Keep drilling until the head falls right off that screw, and once the cover is removed, you'll be able to unscrew what's left of it by hand.
    May 2006
    Nov 2010
    Wow. Easier then I had expected. Thanks.
    Nov 2010
    Sep 2008
    , , Mongolia.
    I think this is cause for Judey to resume his normal drinking posture.
    Sep 2008
    , , Mongolia.
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    ...and replace them with stainless steel hex heads.
    iphone generated fag
    Sep 2010
    Boston, Georgia, USA.
    i did the same to a screw on my oil filter cover, and i used a reverse drill bit to drill it out, and when it just barely cut through the head material it caught and backed it out.
    Nov 2010
    It came out as i was drilling it out with a easy-out. I was just trying to drill the head off with the biggest bit I had and just about when it had drilled off the head, it backed itself out. Any idea, other then the hardware store, where I can pick up SS hex bolts to replace them with?
  1. Replies: 30
    Last Post: 04-03-2009, 01:05 AM
  2. ebay trader screwed me!
    By red72k5 in forum General
    Last Post: 12-20-2007, 06:59 PM
  3. CB 200 screwed up. carbs? gas? (probably) help
    By gskrap in forum Technical
    Last Post: 10-01-2007, 07:49 PM
  4. Screwed by my Buddy
    By jbranson in forum General
    Last Post: 12-09-2005, 09:34 AM
