paddock stands
paddock stands
This is a discussion on paddock stands within the Technical forums, part of the Caferacer.net Forums category; What's the deal with paddock stands for bikes with no center stand? Do you go rear only? Front and rear? Any insight would be appreciated. ...
Results 1 to 10 of 16
Thread: paddock stands
    Senior Member JPellegrino's Avatar
    Sep 2010
    NYC, NY, USA.
    paddock stands
    What's the deal with paddock stands for bikes with no center stand? Do you go rear only? Front and rear? Any insight would be appreciated. Thanks
    "Its amazing what can be done when you don't know you can't do it" Bill Anderson
    Nov 2008
    Your Moms House, USA
    We go both, so we can fit the tire-warmers..
    Sep 2010
    NYC, NY, USA.
    Its just for a street bike that might sit for a few months over the winter. My concern is tire distortion. If tire distortion is a non issue then i will just go with a rear so i can at least change the oil and keep fluids balanced. If tire distortion is a real issue then i will go with both front and rear.
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    a few months won't cause flat spots if the tires are in good shape and properly inflated to begin with.
    do you own a lift?
    iphone generated fag
    Sep 2010
    NYC, NY, USA.
    quote:Originally posted by catboy
    do you own a lift?
    No.
    Aug 2006
    do you still have the center stand you took off?
    Senior Member champ's Avatar
    Apr 2007
    , New Hampshire, Monaco.
    eghey has a boat load of stands....cheap!!!
    Johnnyracer
    Sep 2010
    NYC, NY, USA.
    Its a modern sport bike,side stand only. I have older bikes with center stands and use them all the time. Thanks for your help.
    Mar 2004
    Raymond, NH, USA.
    nice.
    Feb 2006
    If you've got spool mounts on the swingarm, get spools.
    There's assloads of stands on eBay cheap. Flimsy stands suck. Get a known brand unless your buddy already bought a particular offbreed brand and it doesn't suck.
    I do not have a front stand as I have other ways to lift the front while working. I am going to borrow a buddy's Pitbull just to see what it's all about. <- that goes to the steering stem. The ones that lift off the bottom of the forks look spooky to me.
    As far as fluid balancing and tire flattening. Would it be possible for you to set up a calibrated space that you could roll the bike back and forth in? Like say four sections, by my calculations 17.27" long. Every week roll your bike forward to the center of the next section. This will rotate the tire 90*. End of the fifth week, repeat in reverse.
  1. paddock girls..
    By ukTony in forum General
    Last Post: 11-10-2010, 05:26 PM
  2. Static balance stands
    By KeninIowa in forum Technical
    Last Post: 10-09-2010, 01:07 PM
cafe racer paddock stand
paddock stand sucks
stand spools for cafe racer
