CB175 big bore kits, question.
This is a discussion on CB175 big bore kits, question. within the Technical forums, part of the Caferacer.net Forums category; Has anyone here used a cb175 big bore kit? Is there any real advantage to using one on the street around town? Overheating? If anyone ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
    s1b
    s1b is offline
    Junior Member s1b's Avatar
    Orlando, FL, USA.
    Has anyone here used a cb175 big bore kit? Is there any real advantage to using one on the street around town? Overheating? If anyone could educate me, please do!
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Do you have a particular "big bore kit" in mind that you would like comments on?
    s1b
    s1b is offline
    Orlando, FL, USA.
    Wasn't looking at any particular kits. I guess I'm just asking "in general". If you have any kit you recommend, please do! What would be the positives and negatives of this? Is there a better direction to go instead?
    Mar 2010
    , IL, .
    I don't know of any. I was rather hoping that you had seen one and were inquiring about it.
    Someone has 56 or 57mm pistons available and I know you can get oversize head gaskets for Cometic. You'll probably need to bore the cylinder for thicker sleeves to bore out for those big pistons. It can be an expensive option for a street bike unless you are good in the machine shop.
    Someone should be along shortly that has years of Cb160/175 experience that can point you in the right direction.
    Mar 2010
    , IL, .
    s1b
    s1b is offline
    Orlando, FL, USA.
    Teazer, this is one kit I've run across.
    http://rogersmotorcycleparts.com/BigBoreKits.htm
    s1b
    s1b is offline
    Orlando, FL, USA.
    Nov 2008
    56mm is stock for most Honda 125 (and also CB500f.)
    Plus,late 60's's CB250 and later CB/CJ250 are 56mm
    They have various pistons configurations, domed, flat and dished.
    All you need is a friendly parts guy and some time going through parts 'books'
    Last time I did one was 1974, forgotten a lot of stuff since then
    Nov 2008
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    I think I have head gaskets for the 175 +3mm big bore kit but not the pistons and rings.
    http://www.scramblercycle.com
  1. Big bore kitYamaha xs750/ 900cc big bore kit
    By fffast in forum Parts For Sale
    Last Post: 09-23-2012, 07:15 PM
  2. Yamaha XS750/850 Big bore kits "900cc"
    Last Post: 06-15-2012, 08:39 AM
  3. Suzuki GS400 Hi-Perf. Big bore kits
    Last Post: 05-04-2011, 02:53 PM
  4. CB175 this Might be a Crazy question....
    By RICO in forum Technical
    Last Post: 04-24-2010, 12:09 PM
  5. cl450 big bore rejetting question
    By muttblbc in forum Technical
    Last Post: 04-15-2007, 10:57 AM
cb 175 big bore kit
cb100cc kit engines
cb175 big bore
cb175 pistons
honda 175 big bore kit
honda cb 175 big bore kit
honda cb 175 bore and stroke
honda cb160 big bore
honda cb175 piston
