running rich on one side...
This is a discussion on running rich on one side... within the Technical forums, part of the Caferacer.net Forums category; so im fouling out on one cylinder of my CB350, but my carbs are jetted the same. should i back down on jet size on ...
Results 1 to 10 of 15
    Sep 2010
    Boston, Georgia, USA.
    so im fouling out on one cylinder of my CB350, but my carbs are jetted the same. should i back down on jet size on the side that is fowling out, or back down on both?
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    It could be float level differences or maybe that the jets don't flow the same amounts. Try swapping carbs L to R and see if the rich side changes sides.
    It could also be a worn needle jet difference or the needles themselves. Try measuring them and compare or use a caliper and check the diameter every say 10mm on one needle and while the first needle is in the caliper, slide the other needle in beside it. If it sits higher or lower in teh calipers then it's a different diameter.
    Mar 2010
    , IL, .
    Sep 2010
    theyre the factory keins, so i cant swap them side to side, but i can swap floats from side to side.
    Sep 2010
    Moderator imslow's Avatar
    Apr 2003
    , Maine, .
    How long has this condition existed?
    Inertial dynos just make people cranky
    Apr 2003
    , Maine, .
    Sep 2010
    backstory.
    i stopped riding my CB350 afew months back (before it got cold) because the left cylinder wasnt firing all the time. i put new plugs, coils (a pain in the ass to find a NICE set for cheap...i lucked into this set), condenser, points and boots on it, to no avail. in the mean time i replaced the cheap emgo's with K&N's, and put on some different mufflers. yes, i know, get it running right before you modify, but i was halfway hoping that the modifications could fix the problem. when i put the mufflers and filters on it i also went up a couple of jet sizes...to be alittle safe. i found a fuse (the 15A that is in the tube shaped plastic piece attached to the battery box on the negative side) that wasnt blown, but the end was broken, but still attached. when i replaced it, it 90% fixed it, but then it started cutting out again. i pulled the plug and it was fouled out, but the other side was a beautiful golden brown. hence my running rich on one side question.
    Sep 2010
    backstory.
    , Decrepit and Decomposing, .
    Shiny black or dull black?
  1. cb360 lean/rich issue
    By gearhed31 in forum Technical
    Last Post: 12-05-2012, 04:12 PM
  2. CB125S runs rich
    By Thickshady in forum Technical
    Last Post: 06-23-2010, 02:38 PM
  3. CL350 running rich, fowling plugs
    By cafesport in forum Technical
    Last Post: 04-13-2009, 12:49 PM
  4. IF I were a rich man!
    By Pete Casper in forum Bikes For Sale
    Last Post: 05-03-2008, 11:15 PM
  5. one cylinder rich one fine
    Last Post: 03-26-2008, 01:26 AM
