Fork brace
Fork brace
This is a discussion on Fork brace within the Technical forums, part of the Caferacer.net Forums category; Beating on the 175 this weekend, I realized the stock front fender does not brace the front forks well enough (not fun). Is there anything ...
Results 1 to 8 of 8
Thread: Fork brace
    Senior Member YucA's Avatar
    Jul 2010
    Miami, FL, USA.
    Fork brace
    Beating on the 175 this weekend, I realized the stock front fender does not brace the front forks well enough (not fun). Is there anything out there that can be purchased to work with these 31mm front forks?
    Anything wrong with hacking up an old lower triple and making a brace out of it?
    Just looking for options. Everything I come across seems to be <$100...
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Those are relatively long spindly tubes, but teh best place for a fork brace is the top of the sliders. I'd check with Jim at http://www.fastfromthepast.com/servl...ces/Categories and see what he has that could fit or could be modified to work. The dimensions you need are diameter of the top of the slider where the dust seal sits and distance between the legs (center to center).
    Jul 2010
    Miami, FL, USA.
    Thanks for that link, just might have to give him a shout. I was checking out Tarozzi braces as well as a few other brands but haven't really found anything that will bolt on.
    Thats when I started to think what else I could use to make it work. Maybe get a scrap lower triple from a bike with large forks, hack it up and maybe machine the inside to bolt onto the top of the slider.? Then again, that might end up being more of a mission than its worth.
    , Decrepit and Decomposing, .
    If you can do all that, making a stout bridge/brace to make the span from lower to lower...
    shouldn't be much more a challenge.
    What diameter are the tops of your lowers and what is the center to center?
    Nov 2008
    I've made my own when I cant find what I want
    these are for CB360, two different styles
    Senior Member catboy's Avatar
    Aug 2006
    Detroit Metroplex, MI, USA.
    nice work!
    iphone generated fag
    Jul 2010
    Miami, FL, USA.
    That looks clean crazypj. Nice work!
    When I get a chance I'll get the measurements and post them. Making the flat bridge would be the easy part. The part that's slowing me down is getting some clamps that'll work with the forks. But without the measurements I'm pretty much just thinking out loud...
    Jul 2010
    Miami, FL, USA.
    Almost forgot about this thread. Found some leads to some stuff, but nothing solid...
    The tops of the fork lowers are 47mm, and measure about 160mm from center to center.
  1. New Fork Brace
    By tylermoney in forum General
    Last Post: 09-30-2011, 03:12 PM
  2. Fork Brace
    By Rwalker004 in forum Technical
    Last Post: 04-30-2010, 12:53 PM
  3. Fork Brace
    By Whitehurst in forum Parts For Sale
    Last Post: 01-08-2009, 12:47 AM
  4. fork brace
    By 72CafeRacer in forum Technical
    Last Post: 06-26-2008, 06:28 PM
  5. Fork Brace
    By xkillerbx in forum Technical
    Last Post: 05-02-2008, 12:23 PM
31mm fork brace
31mm motorcycle forks
cafe racer motorcycle fork brace
cb360 fork brace
fork brace
honda cb 360 fork brace
honda cb360 fork brace
motorcycle fork braces 31mm sale
