CB360 Carb issue
CB360 Carb issue
This is a discussion on CB360 Carb issue within the Technical forums, part of the Caferacer.net Forums category; So as I rebuild my 75 Honda CB360T, I found an issue that caused me some major concern. When running the motor, fuel would start ...
Results 1 to 6 of 6
    Member mega4ce's Avatar
    Nov 2010
    Los Angeles, CA, USA.
    CB360 Carb issue
    So as I rebuild my 75 Honda CB360T, I found an issue that caused me some major concern. When running the motor, fuel would start spraying out of the right side carb. After running for a few minutes it would also begin to leak fuel out of the overflow valve at the bottom of the carb.
    I decided to rebuild them and as I got started I noticed that I could not locate the coil springs from the vacuum pistons on either carb. This being my first rebuild of a carb, I wanted to know if someone could shed some light on this for me.
    Could the missing springs be what was causing the fuel overflow? Also, does anyone have an idea on where I could get replacement springs?
    I found vacuum piston sets for around $100 but that seems pretty steep when all I need is a couple of springs.
    Damn, I thought that would work...
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    Yes those missing springs could have a lot to do with it. They are going to stay wide open pretty much all the time.
    http://www.scramblercycle.com
    Dec 2006
    Cameron, WI, USA.
    Nov 2010
    great, god knows where the hell they went. but, judging by the wiring and other monkey ass things that have been done to the bike, it doesn't surprise me.
    Nov 2010
    Jan 2008
    Southern Finland
    the overflow can be bad needle valves (the ones that floats are supposed to close) holed float (fills with gas and thus does not float).
    I bought a rebuild kit for mine and it came with new needle valves (and wrong main jets and pilot jets look slightly different too - but that is another story).
  1. cb350 carb issue
    By tommycreeper in forum Technical
    Last Post: 04-12-2012, 05:11 PM
  2. Why is this? Carb issue
    By JackC in forum Technical
    Last Post: 03-31-2012, 03:06 PM
  3. CB350 Carb issue help
    Last Post: 07-12-2010, 10:51 PM
  4. Another Carb issue??
    By mut in forum Technical
    Last Post: 06-28-2008, 10:47 AM
  5. Replies: 5
    Last Post: 05-20-2008, 05:48 PM
carb leaking gas cb360
cb 360 carb springs
cb360 carb leak/overflow
cb360 carb leaking fuel out of overflow
cb360 gas coming out of carb
cb360 vacuum piston
part number for cb360 carb spring
vacuum piston set for 75 cb 360
why would gas leak out of the bottom of the carb cj360
