SL350 VS CB350 Carbs
This is a discussion on SL350 VS CB350 Carbs within the Technical forums, part of the Caferacer.net Forums category; i found out that the latter SL350s had a slide type carb vs the CV carbs on the cb350
im sure im not the only ...
Senior Member
im sure im not the only one that HATES the CV carbs so i thought to myself....."what about swapping to the slide types"?
i think that the slide types are smaller but cant really figure out how much smaller.
anyone ever do it? if so or not why?
thanks
I am Derby\'s Bitch
Senior Member
Those carbs are 24mm but I don't know the direct comparison the a CV. For your info the cam on the SL is the mildest of the 3 (CB,CL,SL) so that size carb is probably best suited to that bikes purpose. Don't know what they would be like on a street going 350 but totally wrong on the track. They are really well suited to a 175 on the track, which is what I use them for
- You may not post replies
- You may not edit your posts
Forum Rules
By jaguar in forum Wanted
Last Post: 07-04-2011, 02:39 PM
By gene03079 in forum Parts For Sale
Last Post: 04-09-2011, 06:57 PM
By muskies666 in forum Technical
Last Post: 09-15-2010, 08:24 AM
By gene03079 in forum Technical
Last Post: 08-02-2009, 09:02 AM
Last Post: 06-22-2009, 12:34 AM
sl 350 carbs on a cb 350
sl350 carbs
sl350 carbs on a cb350
sl350 carburetor vs. cb350
sl350 vs cb350
sl350 vs cb350 carbs
