best source for cb-cl350 mikuni vm carbs kit
This is a discussion on best source for cb-cl350 mikuni vm carbs kit within the Technical forums, part of the Caferacer.net Forums category; I need 2 mikuni 30mm round slide for my cb350.All the used carb i've seen are missing parts or are in bad shape. What is ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Senior Member kochic's Avatar
    Feb 2011
    st-jean-de-matha, QC, Canada.
    What is the best place to get some?
    I saw a couple kit on ebay from speed moto compagny and other.
    Some carbs look cheap knockoff mikuni on ebay.[B)][B)]
    any advice is welcome.
    thanks,
    marc
    honda cb350 1973
    suzuki gs1000 1978
    Senior Member nic579's Avatar
    May 2010
    Pre jetted kits here but I dont know what he charges Post the price here if you find out.
    http://web.me.com/thracing/THR/CB350_K4.html
    This place has the cheapest prices I've found. Mikuni VM30s for $89.95, VM32s for 94.95.
    [email protected]
    402-521-0499
    He advertises in every AHRMA issue. Give him a call.
    Craig
    Feb 2011
    Thanks both of you for the links,
    marc
    honda cb350 1973
    suzuki gs1000 1978
    Senior Member cafe350's Avatar
    Mar 2009
    Columbus, OH, Djibouti.
    Stay away from the pre-jetted carb kits. If you're planning on using lowered bars then the throttle cable they include will need to be trimmed, and so you'd be better off getting a custom job from MotionPro. Also the filters they include are usually cheap. And as far as the jetting goes, you can just use the search function on here to get an idea of what others have done. Then order an assortment of jets, with your mains and pilots going a step up and down...
    Keep your stock carb manifolds. They are angled slightly outward, and you'll need that in order for your carbs and filters to clear the frame.
    \"Hey, McCloud! Get off of my ewe!\"
    Trevor,
    \'72 Honda cl350 (sold)
    \'80 gs450E, the \"spooky \'Zuki\"
    \'04 Kawasaki Ninja 500
    I know the advice has always been to stay away from pre-jetted carbs but I bought my pre-jetted mikunis from Sudco many years ago and I've yet to change anything other than the main jets.
    Craig
    Mar 2009
    Dime City cycles offers a 30mm Mikuni pre-jetted for the 350 and it may be legit. What I really meant to say was to avoid the "complete" kits that have the way-too-long throttle cable an pod filters, when a shorter cable and a pair of Uni filters or K&N's can be had for cheaper...
    Trevor,
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Base everything on what you can read, learn and price here:
    http://www.sudco.com/index.html
    Sudco is where an awful lot of these carbs come into the US. Their prices will give you an idea of how high or low others are pricing.
    I've bought half a dozen carbs from them, not pre-jetted though. Good prices, best info, parts diagrams and parts supply in the country from what I've seen.
    Sudco might not be the cheapest, but they aren't the most expensive either, and you'll get carbs that are probably right off the boat from Japan. I've even requested carbs they don't have and they've got them from Japan for me.
    Feb 2011
    I only need 2 30mm carbs with 2 new intake boots.I dont need cheap emgo filter i already have k&n filters.For the throttle cable i can make a custom one, i have the motion pro cable end fitting kit ( the bit kit in the yellow box).If the VM main jet are all the same i have a bunch of them from the time i worked on snowmobiles.
    I have a 3.3 needle kit, i will have to buy another one.
    I bought parts from sudco last year for and old set of keihin cr special.I cant complaing about their service.
    Thanks,
    marc
    honda cb350 1973
    suzuki gs1000 1978
    Nov 2008
    Your Moms House, USA
    The snowmobiles you worked on two-stroke? If so, none of your stuff will work correctly.
  1. 78 GS1000 Mikuni Carbs
    By 550Kafe in forum Technical
    Last Post: 06-12-2012, 07:24 AM
  2. Replies: 1
    Last Post: 02-20-2012, 11:52 PM
  3. Mikuni carbs
    By xwolfkvltx in forum Technical
    Last Post: 07-21-2011, 08:40 PM
  4. Mikuni VM32 carbs
    By manchildburns in forum Parts For Sale
    Last Post: 10-07-2010, 09:50 PM
  5. Looking for Mikuni vm 30mm carbs
    By cafe350 in forum Wanted
    Last Post: 05-29-2009, 01:31 AM
30mm mikuni carb settings 350 honda
best carbs for. for stock cb350
cb350 mikuni carb kit
honda 1973 cl350 carburator kit in portland oregon
mikuni 30mm honda cb350 stock
mikuni carbs honda cb350
mikuni vm30mm carburetor
used mikuni vm30
what is the best mikuni carb for a modified cb 350
