wheres the oil coming from?
This is a discussion on wheres the oil coming from? within the Technical forums, part of the Caferacer.net Forums category; ok, on the left cylinder, 72 cb350k4. i thought it was the cam seal under the points, so i removed the plate and rotor, and ...
Results 1 to 10 of 13
    Sep 2010
    Boston, Georgia, USA.
    ok, on the left cylinder, 72 cb350k4. i thought it was the cam seal under the points, so i removed the plate and rotor, and the seal was bone dry and looked brand new. so instead, while in there, i put o-rings under every bolt or nut that would come off. put it all back together, and there is still oil that looks to be coming out of my points cover. there is oil on my left plug wire, about 3 or 4 fins under the points cover, oil blown back onto the carb and air filter. for the life of me i cant figure out where the oil is coming from. any ideas?
    Senior Member muskies666's Avatar
    Nov 2008
    Boise, ID USA Earth
    It's coming from inside the engine. Sorry, I had to.
    Nov 2008
    Boise, ID USA Earth
    Either the gasket under the left side cam bearing or one of the o-rings on the rocker arm shafts. Either way the left side cam bearing needs to come off.
    Craig
    Craig
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    nothing to see here....
    Mar 2002
    , , Turkey.
    Mar 2002
    , , Turkey.
    cam box gasket?
    Mar 2002
    , , Turkey.
    cam box gasket?
    Senior Member 44dwarf's Avatar
    Sep 2010
    North Central, Mass, USA.
    1) Wash the motor. 2) Blow dry with exhust from shop vac or compressed air. 3) Spray the cheapest foot anti-fungal spray on motor and all conections. 4) when spray turns white run the motor 5) Look for wet spot.
    44
    PS works great for water leaks too!
    USCRA #944
    WVRC #44
    www.wvrclub.com
  1. wheres Judey?
    By ukTony in forum General
    Last Post: 11-15-2011, 05:47 PM
  2. 'wheres ma money maan...
    Last Post: 10-29-2010, 04:43 PM
  3. wheres my specs!
    Last Post: 10-23-2009, 02:42 PM
  4. wheres branson
    By joe c in forum General
    Last Post: 01-13-2009, 11:58 AM
  5. still coming along
    By slave600 in forum Project Builds
    Last Post: 04-05-2008, 09:43 PM
blowdry motor conection
