CL175 Clutch Feel
CL175 Clutch Feel
This is a discussion on CL175 Clutch Feel within the Technical forums, part of the Caferacer.net Forums category; So just wondering if the clutch feel is normally vague on the little sloper motors or if I have an issue. It does not slip ...
Results 1 to 3 of 3
    Senior Member nic579's Avatar
    May 2010
    CL175 Clutch Feel
    So just wondering if the clutch feel is normally vague on the little sloper motors or if I have an issue. It does not slip and the actual travel for disengaged to engaged is very little, almost on/off. On a side note now that the jets are getting close this thing sounds like a little beast especially since it has coughed out most of the baffles from the stock pipe, so now the tinny rattling is gone too.
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Yes. The clutch is very light and feels almost mushy even with a new cable etc. If it doesn't slip, just develop a light touch.
    Moderator jbranson's Avatar
    Feb 2004
    , , South Sandwich Islan.
    Check your engine number and parts book very closely, the 175's used a couple of different baskets and number of clutch plates. The CL slopers used one more plate than CB's I think, everything needs to be in the right order and the first plate needs the chamfer turned the right way. But yes, they are rather a short throw, and I don't think I've ever felt two of them that were the same. I ended up with a weird combination of barnett springs mixed with OEM springs and one CR two stroke fiber plate to get it the way I wanted for racing.
  1. I feel like a troll
    By Greasyspoon in forum General
    Last Post: 04-14-2012, 03:32 AM
  2. i feel bad
    By ukTony in forum General
    Last Post: 03-08-2011, 08:26 AM
  3. '72 CL175 left switch housing and clutch lever
    By Chip in forum Parts For Sale
    Last Post: 11-23-2010, 08:08 PM
  4. maybe i'd feel silly...
    By coreyjdl in forum General
    Last Post: 09-12-2010, 10:12 PM
  5. Not sure how I feel about this
    By Geeto67 in forum General
    Last Post: 02-22-2010, 07:45 PM
cl175 clutch
cl175 clutch slipping
rattle in cl175 pipes
