is there a vacuum
is there a vacuum
This is a discussion on is there a vacuum within the Technical forums, part of the Caferacer.net Forums category; i have a 79 honda cb400ti and i cant keep it running. there is fresh gas. electrical system is sound. i put my hand over ...
Results 1 to 10 of 15
    Junior Member est1981's Avatar
    May 2010
    San Diego, CA, .
    is there a vacuum
    i have a 79 honda cb400ti and i cant keep it running. there is fresh gas. electrical system is sound. i put my hand over one of the two carbs to see if there was suction and when i did this it fired. i put new filters on and it wont fire.
    there is a tube that vents air from the engine head. does this have anything to do with my carb problem?
    Senior Member hahnda's Avatar
    Dec 2006
    Cameron, WI, USA.
    Have you cleaned your carbs?
    http://www.scramblercycle.com
    May 2010
    San Diego, CA, .
    yeah the carbs are clean
    Senior Member nic579's Avatar
    May 2010
    What you explain sounds like a plugged up dirty carb.
    It sounds like the jets are plugged or I guess your floats could be set horribly wrong or stuck, did you visually inspect the jets to make sure they are clear? I have been surprised in the past by clean looking on the outside jets could be plugged inside. If your tank is rusty the fine rust particles can plug the jets.
    When you say you put new filters on, are you talking stock airbox filter or pods? You will probably need to re-jet the carbs if it's pods (covering the carb and the bike firing up is the clue for you)
    May 2010
    San Diego, CA, .
    i have switched to pods. re jetting sounds like a plan. thanks
    Sep 2008
    , , Mongolia.
    Does choking help? Sounds like a very lean condition.
    May 2010
    San Diego, CA, .
    with full choke it fires a couple of times. no choke no fire. i am going to tear into the carb this weekend. school work got be locked down this week
    May 2010
    San Diego, CA, .
    May 2010
    San Diego, CA, .
    cant wait to finish it and move on to the next one. want to get it running solid by july.
  1. CB360 carb sync vacuum adapters
    By crazypj in forum Parts For Sale
    Last Post: 11-14-2011, 07:29 PM
  2. Coil Spring for Vacuum Piston in Carb
    By mega4ce in forum General
    Last Post: 03-23-2011, 08:55 PM
  3. Keihin vacuum plug
    By john2007 in forum Technical
    Last Post: 07-26-2010, 09:42 PM
