Honda CB 360 Flasher 3 prongs?
This is a discussion on Honda CB 360 Flasher 3 prongs? within the Technical forums, part of the Caferacer.net Forums category; i have 3 wires that should plug into my flasher, but every generic 3 prong flasher i buy doesn't work. When i looked on ebay ...
Results 1 to 10 of 16
    Senior Member tcmoney's Avatar
    Dec 2010
    Provo, UT, USA.
    i have 3 wires that should plug into my flasher, but every generic 3 prong flasher i buy doesn't work. When i looked on ebay for the stock flasher they are all 2 prong. is that how your 360's flashers are?
    Nov 2008
    Been covered a few times on SOHC4.net
    360 has 2 pin flasher, unless it has warning buzzer (I think only CJ had it?)The green wire is spare ground
    I re-wired mine on Thursday, the 'proper' connections didn't work so I swapped connectors from '+' to '-' and it started working. (fitted LED indicators so needed 'LED' flasher, its 3 pin)
    I have no idea why it doesn't work on normal setting?
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    because an led isnt just a bulb.
    Dec 2010
    Provo, UT, USA.
    where's my ground prong supposed to go to then?
    Dec 2010
    Provo, UT, USA.
    So on a '75 360, the stock flasher has two prongs right? and if that's right, does my ground just dangle there? Anybody know? cause the wiring diagram shows three wires coming off the flasher, but on ebay the only flashers for cb 360's are 2 prong
    Dec 2010
    Provo, UT, USA.
    Junior Member MrStinky's Avatar
    May 2011
    Arlington, Texas, USA.
    Being a USA bike, could it be the 3rd wire is for running lights? I have an old Interceptor that uses 3 wire front lights which are always on.
    May 2011
    Nov 2008
    3rd wire is green, so it's ground.
    The other two are black and, I think,grey
    Nov 2008
  1. Flasher unit
    By Clyde in forum Technical
    Last Post: 02-01-2012, 08:45 PM
  2. Replies: 8
    Last Post: 08-23-2010, 07:01 PM
  3. Where is the Flasher Unit Located on CB350?
    By jimd118 in forum General
    Last Post: 08-21-2010, 10:05 AM
  4. 73 CB350 Flasher relay
    By BigIronStudios in forum Technical
    Last Post: 06-23-2008, 06:39 PM
cb350 flasher wiring
honda cb350 flasher location
honds 360 turn flasher
