550 top speed?
550 top speed?
This is a discussion on 550 top speed? within the Technical forums, part of the Caferacer.net Forums category; hey guys, just reading up a bit on my 79 Gs550e. some info on a website said this bikes top speed is 114mph. however, my ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 550 top speed?
    Junior Member adamj.'s Avatar
    Apr 2011
    madison, wisconsin, USA.
    550 top speed?
    hey guys, just reading up a bit on my 79 Gs550e. some info on a website said this bikes top speed is 114mph. however, my bike screams at 70mph, 5500rpm in 6th gear... is this right?
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    114 was when new.....
    What gears are you running?
    is your bike running 100%
    whats redline?
    If you are just trying to "do the ton" you should just get internet slapped
    I am Derby\'s Bitch
    Hmmmm 70 mph = ~113 kph & 114 kph = ~ 71 mph ...could it be that you went and got yourself metrifried
    Feb 2006
    114mph = 8957 rpm using your numbers
    your bike makes max power @9000 rpm stock, doubt it will pull much more than that in to top gear, so sounds about right
    Apr 2011
    It definitely says 114MPH. the bike is running well, not 100% tuned. also, as far as I know the gears are stock (not actually sure what sizes those are). and no, I'm not just trying to hit 100. the guys I usually ride with are all on v-twins, so it's hard to keep up with them on the freeway. I'm thinking about putting a smaller sprocket on, maybe 1-2 teeth smaller. I know that'll screw with my acceleration a bit, so do you guys think that's worth it?
    Dec 2005
    Albany NY
    Ok i just physically bit my tongue not to want to curse around my GF's parents......
    So you claim yourself that the bike is not 100% but want to mess with gears to maybe get a better top speed?
    Wild guess here but pods and cut exhaust?
    Well lets hold off on talkinng about why 100+mph is needed or the fact that over time some of the horses that it had might have left the barn....
    As Ken said it sounds like you are getting the speed that the bike should or at least in a range of it..
    I am Derby\'s Bitch
    Apr 2011
    No pods, 4-1 with a supertrapp muffler...
    Feb 2006
    I did some quicky research to find that peak HP number(like a minute).
    You're not the only guy that thinks his 550 is geared too low stock for highway use.
    Without knowing the internal transmission ratios and riding it I'm not even going to venture a guess as to how bad it'd hurt acceleration.
    Do you really need first gear now? A couple teeth's typically going to be like starting in second or first and a half.
    1 tooth up on the countershaft sprocket makes a detectable difference, 1 or 2 teeth down on the rear not so much, moot point if you can't pull redline in top gear as Ken indicated 5500 is a long way short of the 9k you should be seeing.
    ...now how much do you say you weigh again?
    Feb 2006
    Just to be clear; I'm assuming you're cruising at 5500 and it's just buzzing more than you'd like.
    If will surely go faster than that right?
    If not something's terribly wrong.
  1. 81 CM400T Speed Box
    By simactive in forum Technical
    Last Post: 03-05-2012, 03:28 PM
  2. 97' Speed Triple
    By oneworden in forum General
    Last Post: 09-25-2008, 05:35 PM
  3. top speed of 160!
    By borzwazie in forum General
    Last Post: 08-22-2008, 05:52 PM
  4. NorVin at speed
    By ROSKO in forum General
    Last Post: 08-04-2008, 11:03 AM
  5. speed channel :(
    By JD in forum General
    Last Post: 05-06-2002, 11:58 AM
