which gs1100 engine do i want?
This is a discussion on which gs1100 engine do i want? within the Technical forums, part of the Caferacer.net Forums category; Hello everyone, i have a 81 gs750 i want to put a 1100 engine in. Im planning on building this engine up threw time. Ive ...
Results 1 to 10 of 12
Like Tree1Likes
Thread: which gs1100 engine do i want?
    Junior Member jl22n's Avatar
    Jul 2011
    providence, ri, .
    Hello everyone, i have a 81 gs750 i want to put a 1100 engine in. Im planning on building this engine up threw time. Ive read the newer like an 88 gsx1100 katana engine make the most power stock, but will it fit in my frame without a ton of fabricating? Which 1100 engine is the disired one that all the drag guys want or is it all of them basically?
    Senior Member kochic's Avatar
    Feb 2011
    st-jean-de-matha, QC, Canada.
    All GSXR oil cooled fit with adaptor plates.Plans are "everywhere".
    Gs1100 4v and 1150 fits too with bottom engine mounts.
    Both are easy mod.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    The GSX / GSXR motors (oil cooled) are shorter in length than the air cooled GS mills - which means you either have to place the motor forward in the frame (clears the headers, but moves the sprocket away from the swingarm pivot) or rearward (keeps the sprocket close to the swigarm pivot, but requires custom headers). Technically, keeping the motor rearward is better for chainline wear / preservation, but most people run them at the front as it's easier in the long run.
    But to answer your question, any GS1000, 1100 or 1150 (air cooled) will fit in with the least amount of headaches. They also have the roller bearing cranks which the drag guys find hard to kill.
    Feb 2006
    The black-cased 83 motors are supposed to be the best of the 1100s, not sure I buy there's a difference.
    Junior Member Saltyasf's Avatar
    Sep 2017
    Is this possible I've got a 78 gs750 and I'm about to buy a 79 gs1100 how tough would the mock up mounts or will it bolt up and what else should I worry about
    Junior Member charles's Avatar
    Aug 2017
    Blue Mountains
    Quote Originally Posted by Saltyasf View Post
    The 1100 will bolt straight in, no mods required, the only thing to worry about is an existing smoking problem, I suspect the frame on your bike is an oil cooler and is leaking somewhere.
    Senior Member gs1327's Avatar
    Apr 2009
    Cleveland, Ohio, USA.
    Quote Originally Posted by charles View Post
    No matter how many times I read this, I can't figure out what it means.
    It would be pretty hard to fit one of these seeing as Suzuki didn't make 1100's until 1980.
    Senior Member jalsteve's Avatar
    Aug 2014
    Herts, UK
    if you must fit a big engine in the GS750 frame, though not sure which bike you actually have as the GS750 was made from 76 till 78 and is a 2 valve engine, I guess you must have a GSX750 air cooled 4 valve? But why not buy a complete gs1100, Kat, EF or EFE and just have done! But if you must the GSX1100EFE and later engine (1984-87) is bullet proof and has some improvements over earlier engines. I have one in a Spondon frame at 1260cc, Dyno'd 142hp at the back and 92ftlbs of torque at 7500rpm it's tractor engine.
    As an alternative, the smaller and lighter is the GSX750 TSCC engine from 83 and 84 (not later as the 750s became 700's), its quicker motor than the GS1100 for street use without spending a penny assuming its in good nick. The early GSX750 was re designed for the new Superbike racing class (750cc) in 1983, the Suzuki 750 TSCC (twin swirl combustion chamber) was the result.
    I guess it depends what you are going to use the bike for, if entering field ploughing competitions then go for the GSX1100EFE, if you want something a bit lighter and ultimately a more useable bike then go for the GSX 750 TSCC (an engine that is often overlooked).
    As a foot note, the cranks on GS and GSX engines are roller big end, they are strong but a crank build isn't cheap. Some weld for strength (drag and track racing) but that a one way trip as once welded the crank is not re-buildable.
    Lite the blue touch paper and stand well back!
    Junior Member Iguana's Avatar
    Oct 2017
    GS 1000/1100 engine interchangeability.....
    Charles....thanks for your inspiring advice. I have a 1981 GS1000g with Wiseco 1100 kit in it. Good power etc etc, but I have inadvertently gapped the rings too wide and bike now uses oil & has blow-by......my own stupid fault! I can access a GS1100g engine locally or pull the existing engine down again & fit new rings. If the GS1100g is a direct replacement engine that would be fine. Do you know of any other 'traps' I might encounter in doing this changeover?
  1. GS1100 valve train
    By Teazer in forum Technical
    Last Post: 10-08-2011, 09:05 PM
  2. Monster custom cafe-83 Suzuki GS1100
    By Awall in forum Bikes For Sale
    Last Post: 03-25-2011, 08:20 AM
  3. i want this GS1100, damnit...
    By TheGreg in forum Bikes For Sale
    Last Post: 02-22-2011, 07:24 PM
  4. WTB: CB/CL350 twin engine, Cb400f engine
    By Schwebel in forum Wanted
    Last Post: 03-28-2009, 01:03 AM
  5. '80 GS1100 Swing arm onto a CB750K?
    By james1300 in forum Technical
    Last Post: 01-23-2009, 11:24 PM
1980 suzuki gs550 engine swap
gs1000 engine mods
gs1100 engine for sale
gs1100 motor in a gs750 frame
gs1100e engine for sale
how mch power out of a stock gs 1100 motor
put a gs1100 motor in a gs750
suzuki gs1000 mount to a gs750 frame
youtube80ssuzukigs1100and1150dragbikes
