smiths speedometer drive ratio help
This is a discussion on smiths speedometer drive ratio help within the Technical forums, part of the Caferacer.net Forums category; My rear smiths speedo drive counter has a ratio 2:1, and the stock speedometer says 120 mph, does it matter what speedo I want to ...
Results 1 to 3 of 3
    Member Caferacer311's Avatar
    Sep 2011
    , california, .
    My rear smiths speedo drive counter has a ratio 2:1, and the stock speedometer says 120 mph, does it matter what speedo I want to use with the drive counter?
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    yes they have several ratio's- try googling smiths magnetic speedo's for more info [email protected] vcycle
    Sep 2011
    , california, .
    Thanks! [8D]
  1. Speedometer ratio for CB450
    By spider-man in forum Technical
    Last Post: 04-09-2009, 03:27 AM
  2. cb450 compression ratio
    By red72k5 in forum Technical
    Last Post: 12-10-2007, 03:19 AM
  3. Smiths ATRC tachometer questions
    By Marc Daffinee in forum General
    Last Post: 10-17-2007, 01:48 PM
  4. pre mix ratio conversion
    By notNicky888 in forum Technical
    Last Post: 05-31-2006, 09:11 AM
  5. rieju oil/gas ratio?
    By dan999 in forum Vintage Motorcycle Racing
    Last Post: 04-26-2006, 09:53 AM
smith speedometer counter
smith speedometer gear ratios
smith speedometer sn6317/12a
smiths magnetic speedometer drive ratios
smiths sc3305/04
smiths sc3305/04 drive ratio?
smiths speedo drive ratios
smiths speedometer drive ratios
what smiths motor cycle speedo has a 2-1 ratio
