CB350 Performance Questions
This is a discussion on CB350 Performance Questions within the Technical forums, part of the Caferacer.net Forums category; Hi all, I have a 1973 CB350G and I am having what i believe are some top end performance problems. My bike has great power ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
    Member freeskier's Avatar
    Sep 2011
    Blacksburg, VA, USA.
    Hi all,
    I have a 1973 CB350G and I am having what i believe are some top end performance problems. My bike has great power until about 6000RPM then it just seems worthless. I can get the bike to go up to redline but even in first gear once you are past 7,000 you are better off shifting up to get more acceleration.
    Here is what I have done to the bike overall. I rebuilt the engine with new OEM pistons and have great compression in both cylinders. I have checked the timing and replaced the points and gapped them to spec. Set the valve clearances to spec and have replaced the condenser. (I know new coils may be needed so if anyone could recommend a good brand I'm all ears.) The carbs have been rebuilt, brand new floats set to spec from my workshop manual. Carb jets sizes are 115 main and 78pilot (i believe thats what i put in... will double check). I have new uni-filters and have replaced the exhaust with something a little more open, but still has baffles at the back.
    Battery is on the charger, will give it a go after work. But I wanted to get some opinions on what else I could do. Or perhaps to get a few performance figures from other CB350 riders as perhaps I am expecting too much.
    Mar 2006
    south Orange County, CA, USA.
    Have you done a plug chop? I mean, how did you determine that the jetting you have in there is correct?
    Sep 2011
    No I have not just yet. I was talking to a local motorcycle mechanic who has worked on cb350's for a long time. He recommended jetting up like that to support the UNI filters. But I will do it this evening... fuel starvation?
    Nov 2008
    Your Moms House, USA
    115 mains are stock, I do believe. Uni's are much closer to stock vacuum compared to crap emgos, but that's oiled. Oil dries out.
    Anyway, you are probably lean. Grab 120's and see if it's any better.
    Sep 2011
    Thanks... They are freshly oiled so they should be in good condition. Just out of curiosity could anyone take a stab at what an ideal 0-60 mph time would be. I know that its relative to how well you shift but some ball park figure would be nice.
    Nov 2008
    How much do you weigh?
    Sep 2011
    I weigh 155
    Nov 2008
    With a cb350 being in perfect condition, making as much power as honda claimed in 68, about 6.5 seconds.
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    the latter 350s where slower then the early ones
    I am Derby\'s Bitch
    Nov 2008
    Not sure that's true, Jag. It's true for 750's, but haven't seen enough difference in the various 350's to support that.
  1. CB175 performance build questions
    By jaguar in forum Technical
    Last Post: 04-12-2017, 07:47 AM
  2. 1975 Cb200 performance questions
    By tnahvu in forum Technical
    Last Post: 09-09-2011, 04:24 PM
  3. 2 questions about a cb350
    By Tim in forum Technical
    Last Post: 06-17-2009, 07:49 PM
  4. XS 400 - minor performance questions
    By fateddy in forum Technical
    Last Post: 04-13-2009, 08:18 PM
  5. honda 350 performance questions
    By snorkelfork in forum Technical
    Last Post: 10-16-2007, 10:55 AM
cb 350 0-60
cb 350 0-60 time
cb350 0-60
cb350 0-60 mph
cb350 performance
cb350f 0-60
honda cb 350 0-60
honda cb350 0-60
honda cl 350 0-60
