How to rebuild n Engine
This is a discussion on How to rebuild n Engine within the Technical forums, part of the Caferacer.net Forums category; Decided to rebuild a honda cd250u Engine, 233cc parell twin. Nothing wrong with it, but im doing the cam chain tentioner, What parts do i ...
Results 1 to 10 of 11
    Senior Member StormShadow's Avatar
    Nov 2010
    New England, NSW, Australia.
    What parts do i need,
    Managed to get of ebay,
    cylinder piston,wrist pin, clips, head and base gaskets etc.
    Pair of twin carbs new,
    Full Gasket Kit, x 2
    http://www.ebay.com.au/itm/220653918...84.m1497.l2649
    http://www.ebay.com.au/itm/320772039...84.m1497.l2649
    http://www.ebay.com.au/itm/320657264...84.m1497.l2649
    I have a new Cam chain, and Cam chain tentioner.
    What else do i need?
    2011 Honda VFR800Fi Limited Edition Pearl White and Black two tone.
    2002 Honda Cbr600f4i track bike
    1989 Honda CD250 Cafe
    Senior Member Big Bad Bob Dog's Avatar
    Apr 2009
    Brooklyn, NY.
    A good bench. Good tools. An understanding of how not to over do things. Over tightening ect. Vernier's and micrometers to measure everything you have apart and see what needs replacing or what doesn't. Measure twice.
    I like to have a couple of different manuals, but the official honda manual is best. You would be amazed how some can differ.
    Now you may know all of this, but just checking.
    Also, I would replace the studs. Some people don't but I bet those studs have stretched enough to allow for a weep amongst other things.
    When you get in there you will most likely find something else that needs sorting.
    That's like, your opinion, man.
    Nov 2010
    would you just order bearings for the crank and things?
    Apr 2009
    Brooklyn, NY.
    Plasti gage the bearings first. Wait. Does the CD250 run on plain bearings? If so, I would get them plasti gauged ricki tick. If it's a pressed crank with roller bearings you will have to get someone who can separate the crank and replace them only if they need it.
    Once everything is measured and sorted then go about ordering bearings. Consult your manual on bearing types as well. With some plain bearings there might be markers on your cases indicating exactly which to go by.
    It depends on what sort of life that engine has had of course, but this is why you should check.
    I don't know much about that donk, but it's small cc. So chances are it's nuts have been revved off for half it's life and it could be that passed owners haven't completed routine maintenance.
    Make a plan. Bag and label every single thing and keep it laid out so you remember where everything goes. You don't want to tear everything down (the easy part) then never put it back together.
    Nov 2010
    yeah, i always have a collection of zip lock bags and photo everything. or sometimes i lay things down in a orderly fassion, works well unless your 4 year old decides to help :-(
    well, i know it had a new head gasket, 42,000km on the clock, its got a rattle i suspect is cam chain tentioner, but i have to take the engine appart, barrels off for the cct replacement anyway apparently,
    Nov 2008
    It's a development of the 1980 125 twin.
    Needle/ball bearing crank so don't worry about it unless you can feel play in big end bearings.
    They really need regular oil changes, plus keep an eye on oil level.
    If oil drops too low the left big end fails
    Nov 2010
    well im going to get an engine from a wrecker to for 400 bucks, with 13,000km on it, claimed no noise, ill put that in, and then rebuild the old one.
    Apr 2009
    Brooklyn, NY.
    400 bucks is waaaay to much for one of those. Bargin him down. How many guys are really coming by his joint looking for a cd250 donk?
    Nov 2010
    well, thats with carbs and courier?
    Apr 2009
    Brooklyn, NY.
    For a used engine, sight unseen, that is 'said' to have low kay's. Yeah too much. How much is the shipping? If the guy can prove that the thing has only done as much as he has said, then schwing. But that's old rego papers with matching engine number.
    Go for it if you can afford it, but it's still a common small cc mill. I'd offer him 100 bucks for the lot. If it's a wreckers, they should know it's worth more in pieces.
  1. CB 750 Engine Rebuild
    By rab123 in forum Vintage Motorcycle Racing
    Last Post: 08-28-2011, 05:37 PM
  2. CB 350 Engine Rebuild
    By patritag in forum Technical
    Last Post: 05-16-2011, 08:04 PM
  3. CB360t Engine Rebuild
    By Troy360t in forum Project Builds
    Last Post: 02-23-2008, 07:02 PM
  4. Engine Rebuild
    By krapfever in forum Technical
    Last Post: 07-04-2007, 04:17 PM
  5. engine rebuild
    By roszko in forum General
    Last Post: 05-22-2003, 08:42 AM
2001 honda cbr600 f4i cafe racer
233cc engine parts 2002
cafe racers rebuilding
cd250u 1990 cafe racer parts
engine tear down for 1989 honda cd250u
honda 233cc engine
hondacbr6002003cafeyracer
how to rebuild honda cb360t engine
m6oe honda 233cc engine
