Front end swap..
Front end swap..
This is a discussion on Front end swap.. within the Technical forums, part of the Caferacer.net Forums category; I know people have posted stuff about this a million times. But.... I want to do a front end swap on my 73 CB 750. ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Member racemx51's Avatar
    Nov 2010
    Lewiston, Maine, .
    Front end swap..
    I want to do a front end swap on my 73 CB 750. Mostly for the double disc. Im looking for a GSXR front end.. But what are your opinions?
    Ive seen something about guys just adding a disc to the existing wheel.. What do you guys think? I want it to be nice. But Im seeing this front end swap could get expensive.. And if I get a front end obviously Im going to need a rear wheel to match which looks like it could be interesting?
    Nov 2008
    CB750 has bosses on fork legs for dual disc conversion (although swapping to larger diameter would be a good idea)
    GSX-R forks are probably too short?
    I got some 2002 750 to fit on my Katana (the 'special edition blue anodised outer tubes)
    They are about 2" shorter than stock forks, ~28" compared to 30-1/4" for XS650 and 29-3/4" for Kat, measured from axle center to top of fork nut.
    The XS and Kat are sitting on their wheels so may be another 1/2~3/4" 'unloaded'?
    I don't want to loose ground clearance so I'm still looking for something long enough (no, I don;t want to sell them, they are exact length to replace CB360 forks )
    Sep 2008
    Rochester, New York, USA.
    gsxr forks are okay if used with the clamps they come with, you'll have to slug and reweld the stem to get the required length for the stock steer tube, a 17" wheel in front will be necessary too otherwise steering will be quite slow. I've ridden a 750 with a gsxr front end done right and it was quite good
    Nov 2010
    Lewiston, Maine, .
    Yeah from what Im seeing I can pull the stem out of the CB triple clamp and install it in the GSXR triple.. Which shouldnt be a problem for me.. I think the back end would actually be the harder part to figure out..
    Senior Member kochic's Avatar
    Feb 2011
    st-jean-de-matha, QC, Canada.
    Are you searching an inverted front end?
    I may have one off a 1991 gsrx1100 here.
    I have a 1994 gsxr1100 fork on my gs1000.
    1100 fork are the longest USD that can be bought "cheap"
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    Senior Member 2Stroke's Avatar
    Jan 2012
    Melfort, SK, Canada.
    I love the idea of an inverted fork and dual disc, but I just cant give up my spoked wheels and I would think getting that combo would be a pricey venture.
    Opinions are like ass holes, everyone\'s got one.
    Nov 2010
    Lewiston, Maine, .
    Yeah Id like to stick to spoke wheels too. There is a few ways of doing it but Im looking at all the possibilities right now. Message me kochic if you have one and how much you would want for it..
    Aug 2006
    Portland, Oregon, USA.
    Yoshimura makes extended fork caps for another inch of length, for gsxr forks....
    ~Albert Einstein
    Feb 2011
    You can still go with spokes wheel.
    Marc
    honda cb350 1973
    suzuki gs1000 1978
    Jan 2012
    Marc
    What fork is that? And what did you do with or what wheel are you using?
  1. GT550 front end swap
    By SDmotor in forum Technical
    Last Post: 09-27-2014, 06:18 PM
  2. CB450/900 front end swap
    By fastback33 in forum Technical
    Last Post: 07-20-2011, 01:20 AM
  3. cb500k front end swap?
    By tshaw151 in forum Technical
    Last Post: 10-16-2010, 01:03 PM
  4. front end swap questions for CL350K2
    By dreg14 in forum Project Builds
    Last Post: 01-27-2008, 04:42 PM
  5. how do you swap the front end on a cb350?
    By the new guy - not mad maxx in forum Technical
    Last Post: 02-27-2007, 12:23 AM
73 cb750 inverted fork conversion
gs1000 fork conversion
gs1000 fork swap
gs1000 forks
gs1000 front end swap
gs1000 front fork swap
gsxr forks on gs1000
modern forks for 73 cb750
what is needed to convert cb750 forks to gsxr
