CB360 - running! but smoking carbs.
This is a discussion on CB360 - running! but smoking carbs. within the Technical forums, part of the Caferacer.net Forums category; So this thing hasn't run in 2+ years and I pulled it out of the barn behind our house to start working on it. So ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
    Member Cursh's Avatar
    Jan 2012
    Auburn, AL, USA.
    So far I have.
    1-cleaned and patched the carbs with gorilla glue
    2-Cleaned and sealed the tank.
    3-pulled the head to repair a cross threaded spark plug
    4-installed new points
    5-installed a new battery.
    As it sits there are a bunch of holes late in the exhaust, but nearly all the smoke is coming from the air boxes and sides of the carburator (there is a brass looking circle above the idle adjustment screw - its coming from there. and everywhere behind it airbox vents - screw holes in the airbox, etc.)
    I would give my self a 4 out of 10 in mechanical aptitude as it relates to combustion engines. (and a 7 out of 10 otherwise)
    I searched but A: I'm practically illiterage so I can't spell carburator and B: I'm pretty terrible at imputing appropriate search terms
    *1975 honda CB360 - Excuse me, English is my second language and I\'ve been drinking.
    I work at STAMP
    my work can be seen here
    Senior Member busapilot's Avatar
    Jun 2009
    Westminster, Maryland, USA.
    Keyster carb rebuild kit - http://www.siriusconinc.com/search_r...&search=search
    Remove air box until the issue is found and fixed. Provide picture - can be worth a 1000 misspelled words.
    Check the rubber carb mount insulators for cracks. - http://www.bikebandit.com/houseofmot...9224#sch400006
    Any residual oil left on any hot parts (valve head?) will smoke until burned off. I imagine gorilla glue would smoke up like a factory too. Try J-B Weld instead.
    Every time I start thinking the world is all bad, then I start seeing people out there having a good time on motorcycles. It makes me take another look. - S.M.
    Senior Member muskies666's Avatar
    Nov 2008
    Boise, ID USA Earth
    Did you adjust valves and set the timing properly when you put the head back on?
    Mar 2006
    south Orange County, CA, USA.
    I don't know if this has anything to do with the "carbs smoking" problem, but it's funny.
    Jan 2008
    Southern Finland
    the gorilla glue part might need a little clarification - as in what did you glue?
    Nov 2008
    Usually carb diaphragms.
    If they are split get some JBM replacements, about $45.00 for pair including shipping
    Jan 2012
    Auburn, AL, USA.
    does this downgrade me to a 3 out of 10 with combustion engines?
    I patched a few pin holes in the Diaphragms. It appeared that I wasn't the first to do it. I'll replace them with new when I have the $ laying around. I'm sure there are other things more pressing as well. My forks need attention (suggested in my last post) and I have a few wiring bugs (headlight doesn't work). Until then I'll stick to pedal bikes.
    @busapilot - would you like a picture of it smoking? I'm not sure what I should photograph for you, but I would be happy to. I have a few hours to kill this afternoon and could get into it a little bit more.
    As far as setting the valves and timing. I *"think"* the timing is set right, but I really haven't enough experience to know what I'm looking for. My test light doesn't light AT ALL when I do what the Clymer instructs to set timing. (it lights elsewhere)
    As far as the valves, I can't remember what my hang up was the last time I was looking to adjust them . . . or it was just very easy/ they appeared to be properly set . . . either way, I will start there this afternoon.
    Thanks for all of your help so far.
    -Ben
    I work at STAMP
    Jun 2009
    I'm pretty new to this too, but I've been fixing my CB weekly since I bought it two years ago. I'm visual and seeing it smoke (at idle and under throttle) can narrow down some of the culprits.
    Nov 2008
    Here's link. I couldn't find it last time I was looking
    I changed a pair, they seem to be pretty good and it's easy fix.
    I'm going to get a couple as I have 4 360's
    http://jbmindustries.com/Keihin_diaphragm.html
    Jun 2009
    @PJ - THAT'S AWESOME!
  1. cb360 carbs
    Last Post: 06-30-2011, 11:33 PM
  2. cb360 up and running, but no lights!
    By tcmoney in forum Technical
    Last Post: 03-16-2011, 02:15 AM
  3. Wanted: CB360 Carbs
    By Saml01 in forum Wanted
    Last Post: 04-03-2010, 07:56 PM
  4. cb360 carbs
    By Johnny Gaijin in forum Technical
    Last Post: 10-09-2009, 01:30 AM
  5. CB360 Carbs
    By Saml01 in forum Parts For Sale
    Last Post: 08-07-2009, 12:07 AM
'timing light cb360
1975 cb360 carb photo
cafe racer auburn alabama
cb 360 diaphragma position
cb360 smoking out of carbs
honda cl360 carb rebuild kit
running in a cb360
timing light cb360
