which relay for ignition switch?
This is a discussion on which relay for ignition switch? within the Technical forums, part of the Caferacer.net Forums category; hello folks, need some input on a relay for the ignition setup i'm trying to pull off. i want to use a 4-pole relay with ...
Results 1 to 10 of 15
    Senior Member jackshite's Avatar
    Jul 2009
    Austin, Texas, USA.
    hello folks,
    i want to use a 4-pole relay with the 'switch' i've come up with. i need to know where to find one appropriate to my application.
    sealed, doesn't need to be more than 15-20 amp capacity, wired coming off the fused positive from the battery, relay to ignition switch (a heavy-duty jack, hot from relay, ground to frame), then on to coils, headlight switch, etc.
    need heavy duty but small and easily hidden in underseat electronics...
    suggestions where to look? so many options, many of which seem like overkill for this particular app.
    Nov 2008
    Shouldn't need heavy duty, 5 amp mini should be fine (one for each coil?)
    You could encapsulate mini relays
    Kawasaki have some relatively small circular relays, you could probably snip them out of a junkyard harness?
    I'm going to run ground side through kill switch
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    I got mine from Eastern Beaver http://easternbeaver.com/Main/Elec__...ys/relays.html but you can probably get them from many other places on line.
    Mar 2010
    , IL, .
    Senior Member gs1327's Avatar
    Apr 2009
    Cleveland, Ohio, USA.
    Not trying to be a dill, but why 4 pole?
    Single pole relay with 20-40 amp capacity is compact and dirt cheap, even available at the corner auto parts chain store.
    Apr 2009
    Look for a car horn relay. Most common are 30a and they're dirt cheap. The one Teazer posted will do the trick too.
    Jul 2009
    Austin, Texas, USA.
    just grabbed a 4-pole 30 amp from the auto store. thanks for the replies.
    in answer to why i used this particular relay, a little background...
    i've been playing guitar for a really long time. played music professionally for the better part of 20 years.
    i was talking to a pal about coming up with a cool ignition that wouldn't be a big ugly keyed stocker, or just a toggle switch hidden away somewhere. he told me about seeing a custom harley that had an 1/8th inch jack (like a mini headphone jack) for the 'key'.
    i have a ton of guitar and amp parts stashed. i came up with an idea to use a 1/4" speaker jack, with a 1/4" plug from a custom guitar cable as my 'key'. the plug is really small, really cool looking machined brass, and the way the speaker jack is wired to the relay, when i insert the plug, i connect the ground, turning the power on.
    i'm super stoked, it worked like a charm, fired the engine for the first time tonight!
    Jul 2009
    Austin, Texas, USA.
  1. Early 80's Suzuki Ignition Switch
    By Hellions in forum Wanted
    Last Post: 10-07-2011, 11:28 PM
  2. headlight relay
    Last Post: 07-27-2011, 10:45 PM
  3. Location of Honda CB360 Ignition switch?
    By shidifen in forum Technical
    Last Post: 01-29-2010, 03:22 PM
  4. Wiring an Ignition Switch
    By ZouLou in forum Technical
    Last Post: 08-17-2009, 09:43 AM
  5. CB500T Ignition Switch / Lockset
    By KrooklynCB in forum Wanted
    Last Post: 10-14-2006, 06:50 PM
40 amp relay for harleys
