Starter stuck
Starter stuck
This is a discussion on Starter stuck within the Technical forums, part of the Caferacer.net Forums category; So the 360 has been sitting still for a few weeks so I went out to start it up and let the oil move and ...
Results 1 to 8 of 8
Thread: Starter stuck
    Junior Member larsbrunsvold's Avatar
    Jul 2010
    Davis, CA, USA.
    Starter stuck
    So the 360 has been sitting still for a few weeks so I went out to start it up and let the oil move and battery charge. After cranking for sometime it started up but the starter wouldn't disengage. I hit the ignition switch off and it still cranked. Pulled the key out and it still cranked. I finally had to disconnect the battery to make it stop cranking. I disconnected the starting wire from the controls, reconnected the battery and it automatically started cranking again. Why would it be stuck on? Is it something in the starter itself that I would have to take a look at or a short somewhere else? Still cranks without a key and the ignition swith off?
    1974 CB360
    1986 XR250
    The starter solenoid is stuck. Smack it with a hammer on the side.
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    WERA 119
    CCS 119
    CRA 119
    AHRMA not anymore
    Evan Esar
    Jul 2010
    Davis, CA, USA.
    Thanks Ken. I'll give that a shot in the morning
    1974 CB360
    1986 XR250
    Jul 2010
    Davis, CA, USA.
    1974 CB360
    1986 XR250
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    relay for sure is stuck on(engaged) but before you hook power back up.....diconnect one lead to the relay and ck that continuity breaks (opens)between the two main cables. try to tap on top of relay to release it but it may do it again due to corrosion,burnt contacts,bad spring, you may want to replace it as this could be a problem if you are out riding..
    [email protected] vcycle
    Jan 2010
    Jul 2010
    Davis, CA, USA.
    Thanks guys. The hammer trick worked for the time being but I am going to delve more deeply later on to find out what the actual cause of it was.
    1974 CB360
    1986 XR250
  1. Stuck rings??
    By hillsy in forum Technical
    Last Post: 01-22-2012, 07:26 PM
  2. Getting Stuck Brake Out
    By JackC in forum Technical
    Last Post: 10-17-2010, 05:09 PM
  3. Cb 450 stuck on
    By muskies666 in forum Technical
    Last Post: 04-06-2010, 11:36 AM
  4. Cam Chain Stuck
    By BrianH in forum Technical
    Last Post: 03-04-2009, 06:38 PM
  5. CB200 kick starter shaft and starter clutch Q's
    By scott.v in forum Technical
    Last Post: 07-03-2008, 09:04 PM
