82 Cb 900 F Carb replacement?
This is a discussion on 82 Cb 900 F Carb replacement? within the Technical forums, part of the Caferacer.net Forums category; Hello all! I am a young and fairly new mechanic currently working on a 1982 CB 900 F, and the carburetors look like they have ...
Results 1 to 3 of 3
    Junior Member dynamo4reese's Avatar
    Apr 2012
    Hello all! I am a young and fairly new mechanic currently working on a 1982 CB 900 F, and the carburetors look like they have been through the ringer. My associate (the old wise mechanic) wants me to switch them out for another set of less corroded/gunky carbs instead of cleaning them. Is there another set out there that will fit? It looks like the CB 750 F DOHC carbs may fit just fine, but they're still a bitch to clean and re-build and I was wondering if a set of the SOHC carbs could be swapped in with little to no rack modification? Any recommendations?
    Thank you so much.
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    almost sure that the spacing is different DOHC VS SOHC
    Also i assume that the SOHC carbs are smaller
    I am Derby\'s Bitch
    Nov 2008
    It's going to be easier to find and use the stock CV carbs, (until you build a cafe and try to fit pods)
    Stock carbs, stock airbox, runs better
    The Kei-Hin CV's will NEVER run right with pods (it's been tried since the 80's)
    Otherwise, switch to Mikuni or CR
  1. Rim Replacement Question
    By JackC in forum Technical
    Last Post: 09-20-2011, 10:54 AM
  2. Gearshift Replacement
    By rmtsurf80 in forum Technical
    Last Post: 05-28-2011, 02:13 AM
  3. cb500F rec/reg replacement?
    By tshaw151 in forum Technical
    Last Post: 12-11-2010, 11:29 AM
  4. Replies: 5
    Last Post: 05-20-2008, 04:48 PM
  5. Replacement petcock
    By lefty337 in forum Technical
    Last Post: 09-10-2007, 04:58 PM
