Shifter rubbers?
Shifter rubbers?
This is a discussion on Shifter rubbers? within the Technical forums, part of the Caferacer.net Forums category; Hi, I am trying to bring the original shifter and brake pedal back to life and i have Kalguard'ed them already. The rubbers were quite ...
Results 1 to 5 of 5
    Member Tonto's Avatar
    Jan 2012
    Shifter rubbers?
    Hi, I am trying to bring the original shifter and brake pedal back to life and i have Kalguard'ed them already. The rubbers were quite worn and i have taken them off before coating the levers.
    Any suggestions on whats best to put back on to the leavers? I was thinking of something like dip&grip which is used on tool handles ect.
    Any suggestions?
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    Are you sure that the OEM rubber is not available? Or get something from another bike. I bought a bag of 10 for an RZ350 on ebay and I use them on everything.
    Senior Member Emit R Detsaw's Avatar
    Oct 2009
    Phoenix, AZ, USA.
    I use Nighthawk 250 shift rubbers. Work dandy. $2.00 a pop.
    Dip-n-Grip will NOT last very long in the applications you're inquiring about.
    I believe we have run out of trolls.
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    lots of shift rubbers that will work... use an old condom or fuel/oil hose if your real cheap...ha
    [email protected]
    Jan 2010
    [email protected]
  1. Manx alloy tank supporting rubbers...
    By Jouni-Pekka Uitto in forum Wanted
    Last Post: 05-18-2012, 03:12 PM
  2. Rubbers, Tires, Treads.....
    By Gambler in forum General
    Last Post: 02-24-2010, 04:51 PM
  3. tank rubbers
    By mike elliott in forum Technical
    Last Post: 01-14-2010, 07:05 PM
  4. 350 shifter rebuild... and a new friend!
    By cafesport in forum Technical
    Last Post: 07-11-2009, 08:21 PM
  5. Need Shifter Linkage for CL350
    By JackC in forum Wanted
    Last Post: 06-08-2007, 09:18 PM
