front brake pads: tight fit on disc
This is a discussion on front brake pads: tight fit on disc within the Technical forums, part of the Caferacer.net Forums category; ok, so here's what I'm running into: the previous owner of my Z1 added a second front disc brake. When I bought the bike, the ...
Results 1 to 5 of 5
    Feb 2009
    Fort Knox, Kentucky
    the previous owner of my Z1 added a second front disc brake. When I bought the bike, the front brakes were frozen so I took them apart and rebuilt them as well as installing new pads. The calipers now brake perfectly fine. The thing is, the pads are rubbing against the discs even when no brake is applied, causing the front wheel to not spin freely.
    Any thoughts on how to rectify the problem? should I sand down the pads or ride it until the pads wear down? or should I take the calipers apart again and see if I missed something?
    Any help would be appreciated.
    Take the pads out and check the distances between the disc and the piston. Also the distance between the disc and the fork leg / calliper mounts. Could be a spacer issue with the axle.
    I wouldn't try and ride it to wear the pad down - that may take some time and is potentially dangerous. Worst case scenario is you grind some meat of the offending pad.
    Feb 2009
    Fort Knox, Kentucky
    thanks for the tip, I'll give it a try
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    some bikes have more rotational friction than others- are you sure it is too much?
    what pad and caliper is dragging? remove one or the other to eliminate one. did you ck the piston clearances, where they a slip fit into the caliper? all corrosion removed? proper dot fluid as to not swell seal. m/cyl ok ?
    poor caliper alignment? where the old pads worn on an angle?
    [email protected] vcycle
    Jan 2010
  1. CJ250T Front disc brake problems
    By belch_brother in forum Technical
    Last Post: 11-11-2009, 04:36 PM
  2. Converting front disc brake hub to rear wheel?
    By borzwazie in forum Technical
    Last Post: 03-21-2008, 11:14 PM
  3. Disc Brake Help
    By 350Four in forum Technical
    Last Post: 02-12-2007, 08:32 AM
  4. brake pads
    By imslow in forum Technical
    Last Post: 09-15-2006, 02:57 AM
  5. CB450 forks, disc brake, front wheel.
    By UngaWunga in forum Parts For Sale
    Last Post: 04-05-2006, 07:50 PM
cb750 brake pad tight
