DT100 crank bearing replacement
This is a discussion on DT100 crank bearing replacement within the Technical forums, part of the Caferacer.net Forums category; I'll be replacing crankshaft bearings soon on a '79 DT100. Do I need to be concerned with setting end play on something like this, or ...
Results 1 to 10 of 15
    Senior Member Luckypabst's Avatar
    Oct 2011
    Costa Mesa, CA, USA.
    I'll be replacing crankshaft bearings soon on a '79 DT100. Do I need to be concerned with setting end play on something like this, or is it a simple R&R of parts?
    Thanks
    Chris
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    just mains or big end rod too? big end rod should have a spec listed some place. There is also a runout spec on truing the crank.
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    Jan 2009
    Bike:
    Buell X1
    Honda CB750C (runs)
    Oct 2011
    Just mains. I'm hoping it didn't suck any debris into the rod bearing... the timing side main is blown: grumbly with excessive play. I haven't split the case yet - waiting on parts before getting into it.
    Chris
    Oct 2011
    Chris
    Jan 2009
    see how the old one is. Its probably just seated against the crank.
    Bike:
    Buell X1
    Honda CB750C (runs)
    Jan 2009
    Bike:
    Buell X1
    Honda CB750C (runs)
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    if you have the engine that far down you should at least have the crank ck'd on centers to ck .
    a lot of single yamaha's used shims to set axial play...ck the parts book and shim per manual the crank should be as centered as possible in the cases to keep cyl wear even. a few things on assembly, install the bearings properly(heat/freeze),do not hammer them in especially on the inner race. when installing the crank do not hammer it in,heat/freeze/lube pull in..do not drive it in! when ready to put the cases together, heat/freeze and install a spacer between the crank fly wheels(i use feeler gauge stack),180 degrees from big end pin) so it stays true and then assemble it, you should not have any resistance if done correctly.. spin gearbox and crank and if needed unload main bearings while it still has the shim gauge in between flywheels. ck gearbox operation too before proceeding...one last thing, do not use cheap bearings with the wrong class fit either..... [email protected] vcycle
    Jan 2010
    Oct 2011
    Thanks for the pointers! I'm pretty sure the owner ordered the All Balls bearing & seal kit. And I'm waiting on a case separator and a crank puller so there won't be too much ham-fisting going on.
    Chris
  1. CL350 roller crank conversion to ball bearing
    By Juan Cortez in forum Technical
    Last Post: 04-27-2012, 05:13 PM
  2. 75 dt100
    By parts413 in forum Project Builds
    Last Post: 02-24-2012, 01:43 PM
  3. 160/175/200 Cam Bearing
    By aaron in forum Parts For Sale
    Last Post: 12-14-2010, 07:49 AM
  4. WTB: '71 CB or CL 450 Crank
    By Abbott in forum Wanted
    Last Post: 05-09-2010, 10:27 AM
  5. no crank help!!!!!!
    By weside in forum Technical
    Last Post: 02-06-2007, 07:29 PM
ag 100 and bajaj crankshafts
dt100 bearing kit
dt100 crank
dt100 crank bearings
dt100 dissassembly crankshaft
split cases on dt 100
splitting case on dt100
yamaha ag 100 crankshaft replacement
yamaha dt 100 spltting case
