New Bonnie swingarm on pre-OIF frame?
This is a discussion on New Bonnie swingarm on pre-OIF frame? within the Technical forums, part of the Caferacer.net Forums category; Probably a waste of space to ask here since most are Honda fans, but has anyone looked at putting a swingarm from a "new" Triumph ...
Results 1 to 5 of 5
    Member Bull Gear's Avatar
    Feb 2012
    Locust, NC, .
    Probably a waste of space to ask here since most are Honda fans, but has anyone looked at putting a swingarm from a "new" Triumph Bonnie on a pre-OIF frame?
    I am hatching plans for my next build. I am considering putting modern Bonnie suspension under a vintage 650 motor and frame. I know its far from cutting edge technology, but it should provide decent handling in a somewhat "traditional" looking package.
    Senior Member JPellegrino's Avatar
    Sep 2010
    NYC, NY, USA.
    Not at all. I personally have no idea what the [email protected]# you’re taking about, but sure someone else here does[^].
    "Its amazing what can be done when you don't know you can't do it" Bill Anderson
    Member makegooddecisions's Avatar
    May 2012
    , , USA.
    Oil In Frame
    Senior Member TCed's Avatar
    Dec 2011
    traverse city, mi, USA.
    might want to go here triumphrat.net and ask that question
    ed
    Senior Member joe1028's Avatar
    Jan 2010
    inver grove heights, mn, USA.
    pre oil in frame can be a unit or preunit bike.
    a lot depends on what you use and what you are trying to accomplish....you may want to stiffen the frame up, pickup some hagon shocks, modify the forks instead of starting at the swing arm. you probably have a bolt together frame which can use some help to eliminate any movement.
    go to www.britbike.com under modified or triumph section- a lot of talent and help there...
    good luck,[email protected]
  1. 1979 Triumph Bonnie
    By leo in forum Bikes For Sale
    Last Post: 02-28-2011, 06:46 PM
  2. SL swingarm on a CB frame
    By Marc B in forum Vintage Motorcycle Racing
    Last Post: 10-11-2010, 01:30 PM
  3. 79 Bonnie Cafe Racer
    By b_rant in forum Technical
    Last Post: 06-24-2006, 09:36 AM
  4. Hinkley bonnie
    By keith miller in forum General
    Last Post: 10-15-2003, 12:57 PM
  5. 73 Bonnie in A basket
    By Britbiker in forum Parts For Sale
    Last Post: 08-15-2003, 09:00 AM
boxed swingarm for triumph oif
new triumph swingarm frame
pre oif
triumph 650 swingarm
which side of frame does the nut go for swing arm on triumph 650
