78 GS1000 Mikuni Carbs
This is a discussion on 78 GS1000 Mikuni Carbs within the Technical forums, part of the Caferacer.net Forums category; What would cause the bottom of 1 out of 4 carburetors to corrode? I pulled my bike into the garage after a ride saturday and ...
Results 1 to 7 of 7
    Member 550Kafe's Avatar
    May 2012
    New Bern, North Carolina, USA.
    I pulled my bike into the garage after a ride saturday and gas was pouring out of the #2 carb overflow tube. I thought stuck float and pulled the bowl. I was amazed to see that the throttle body was horrible corroded. I pulled the bank off and removed the remaining 3 float bowls. They were nearly perfect. I dont get it.
    Does anyone have a spare they could part with? I believe its a 26mm as measured from the inside diameter of the carb where it attaches to the intake boot (pipe).
    77 CB550K
    79 GS1000
    73 CB350 Twin
    74 TX500
    Senior Member raven's Avatar
    Jan 2009
    milledgeville, ga, USA.
    Was the drain screw stuck? If so maybe the other three got drained but that one did not?
    Bike:
    Buell X1
    Honda S90 (box of parts)
    Honda CB750C (runs)
    May 2012
    Drain screws came out fine, in fact, everything including the jets look new as if the previous owner rebuilt them reguardless of the corrosion. WTF...really?
    77 CB550K
    79 GS1000
    73 CB350 Twin
    74 TX500
    Senior Member nic579's Avatar
    May 2010
    I have a set of RD400 carbs that the previous owner tried cleaning with laundry detergent I think. He claimed they were cleaned and dried and left sitting for some time in which the cleaner was still working on the aluminum turning it to powder.
    May 2012
    I have no idea what was done, but to have 1 of 4 carbs rot out like that is strange. I guess its time to search fleabay for a carb set for parts.
    77 CB550K
    79 GS1000
    73 CB350 Twin
    74 TX500
    Nov 2008
    Which carb? #1 and #2 are usually the most messed up as people leave bike on sidestand.
    Fuel inlet is between #2#3 so all the crap, water, 'stuff' gets into #2 carb before any other
    May 2012
    Thats what I was thinking, PJ. The whole bottom side looks like swiss cheese. It must have sat for quite a while for it to rot out like that. The previous owner hacked off the center stand and most of the right side P-peg mount to make room for a shitty 4-1 headder can.
    77 CB550K
    79 GS1000
    73 CB350 Twin
    74 TX500
  1. Replies: 1
    Last Post: 02-20-2012, 10:52 PM
  2. Mikuni carbs
    By xwolfkvltx in forum Technical
    Last Post: 07-21-2011, 07:40 PM
  3. best source for cb-cl350 mikuni vm carbs kit
    By kochic in forum Technical
    Last Post: 03-30-2011, 03:14 PM
  4. Mikuni VM32 carbs
    By manchildburns in forum Parts For Sale
    Last Post: 10-07-2010, 08:50 PM
  5. Looking for Mikuni vm 30mm carbs
    By cafe350 in forum Wanted
    Last Post: 05-29-2009, 12:31 AM
1978 suzuki gs1000 mikuni carb identification
carb setting for a gs 1000
carbs are overflowing with gasoline. gs1000
gs1000 carb overflow
gs1000 pouring gas out of carb
mikuni carb rotting
mikuni gs1000 carburetors
mikuni suzuki gs 1000e carb diagram
suzuki gs1000 new bern
