Honda triple clamps for 35mm forks
This is a discussion on Honda triple clamps for 35mm forks within the Technical forums, part of the Caferacer.net Forums category; Wanting a plug and play setup to convert my CB350K2 from 33mm to 35mm forks, I did some research on the web and picked up ...
Results 1 to 8 of 8
    Fairfax, VA, USA.
    Wanting a plug and play setup to convert my CB350K2 from 33mm to 35mm forks, I did some research on the web and picked up a couple pairs of 1972 SL350K2 triple trees from eBay. The lowers have the double pinch bolts and measure 35mm diameter. However, the uppers measure just 33mm diameter.
    Is the SL350K2 upper triple clamp similar in design to the one that was originally fitted on my CB350 to capture the fork? I need to be able to adjust the front ride height by raising or lowering the forks through the triple clamps. Am I missing something? My research indicated this was a bolt on affair. Am I supposed to machine the holes in the upper clamp to fit 35mm forks?
    I know some of you guys are going to say just get CB750 or CB550 clamps but I've already been down that road once and don't want to mess with swapping steering stems. Thanks.
    Nov 2008
    If you get an early CL one they are pressed in with an expander plug without any welding.
    You only need a bar to fit inside stem, press out expander then press out stem.
    I'm going to fit it to a 41mm Suzuki yoke (when I get round to grinding off the weld)
    Senior Member muskies666's Avatar
    Nov 2008
    Boise, ID USA Earth
    CB450 top clamp?
    Nov 2008
    Boise, ID USA Earth
    CB450 top clamp?
    Fairfax, VA, USA.
    I'm thinking that the SL350K2 forks neck down from 35mm to 33mm between the triple clamps for some reason. Apparently these tapered forks are somewhat common on off-road machines, and even some modern sport bikes. Seems I'm back to using the adjustable hand reamer....
    Fairfax, VA, USA.
    Senior Member busapilot's Avatar
    Jun 2009
    Westminster, Maryland, USA.
    If that doesn't work for you I've got some 35mm trees for sale. https://www.caferacer.net/forum/topic.asp?TOPIC_ID=22412
    One is top and bottom ('72 Suzuki GT750?). The other is just top (can't identify make/model/year).
    Every time I start thinking the world is all bad, then I start seeing people out there having a good time on motorcycles. It makes me take another look. - S.M.
    Jun 2009
  1. '76 honda xl250 35mm 4 pinch bolts triple tree
    By kochic in forum Parts For Sale
    Last Post: 02-05-2012, 05:06 PM
  2. XS650 35mm triple clamps
    By bullockcm in forum Wanted
    Last Post: 04-04-2011, 07:00 AM
  3. SL175 Triple Clamps
    By spencer9283 in forum Technical
    Last Post: 07-26-2010, 10:07 PM
  4. CB550 Triple clamps
    By lonewolf in forum Wanted
    Last Post: 01-16-2010, 07:02 PM
  5. Shimming fork tubes to triple clamps
    By whiskeysid in forum Technical
    Last Post: 11-06-2009, 08:22 AM
35mm fork clamps
cb450 triple tree for sale
forks don't come through new triple tree cafe racer
honda cb550 triple tree
honda fork identification
raising fork honda cb350
raising the forks in the triple clamps
triple clamp forks honda
will 33mm trees fit 35mm fork tubes
