Maund Cast Aluminum Drum Brake Vents
This is a discussion on Maund Cast Aluminum Drum Brake Vents within the Technical forums, part of the Caferacer.net Forums category; Have you guys seen these? Anybody used them? http://maundspeed.blogspot.com/2011/04/brake-vent.html http://www.maundspeed.com/chopper_parts.html...
Results 1 to 5 of 5
    Fairfax, VA, USA.
    Moderator joe c's Avatar
    Mar 2002
    , , Turkey.
    mike morse says his brakes are good to like 850 degrees or something like that. gt750 dosnt need em.
    Fairfax, VA, USA.
    Doesn't the GT750 4LS already comes with air scoops from the factory, therefore making aftermarket scoops redundant?
    Yes they do.
    Do you have brake fade at this point that you feel you need to solve? I've seen brakes with something like this part welded on in the past. Just not sure how effective it really is. If it's something you want to add to your bike to look cool then go ahead and get it. But in a six or 8 lap race I don't know how big a factor brake fade is with proper sized brake and good arched shoes to fit the drum.
    Fairfax, VA, USA.
    No problems with brake fade yet as my bike is still being constructed. I was just brainstorming things I might like to do while I've got the front hub in my hands. Soon the shoes will get new friction material and they will get arced. Then I'll finally get to lace it up to a new rim and fit the tube and tire so the bike will be a roller.
  1. drum brake for cerriani sliders
    By Burns in forum Vintage Motorcycle Racing
    Last Post: 08-12-2012, 11:05 PM
  2. Brake drum Lathe
    By nic579 in forum Technical
    Last Post: 10-31-2011, 08:40 PM
  3. 69' cb450 drum brake $100
    By snorkelfork in forum Parts For Sale
    Last Post: 11-20-2009, 08:32 PM
  4. drum brake porn
    By freedomgli in forum General
    Last Post: 10-07-2009, 10:19 PM
  5. front drum brake
    By lonewolf in forum Vintage Motorcycle Racing
    Last Post: 03-27-2009, 04:05 AM
cafe racer vented brake drums
cafe racer vented front drum brake hub
front drum brake venting
front drum brake vents
how to make brak drums vent
how to vent drum brakes
maund air scoop
venting motorcycle drum brake
vents for motorcycle drum brakes
