'71 CL175 Race Bike Build Questions
This is a discussion on '71 CL175 Race Bike Build Questions within the Technical forums, part of the Caferacer.net Forums category; Trying to get this thing ready for the next race season. However, one of the stud holes where the exhaust bolts on in the engine ...
Results 1 to 10 of 11
    Junior Member sambo's Avatar
    May 2011
    Attleboro, MA, USA.
    Trying to get this thing ready for the next race season. However, one of the stud holes where the exhaust bolts on in the engine is stripped. Anyone have any suggestions on how to fix this? It was like that when I got it.
    Also, does anyone know what jetting is recommended for uni pod filters or velocity stacks(I think 90 main 38 slow is stock)?
    What gearing is ideal for Loudon? Leave it stock or change it?
    Fork oil weight recommendations?
    Thanks!
    Fairfax, VA, USA.
    I would use a helicoil thread repair. Buy the repair kit for whatever size your exhaust stud is supposed to be (M8x1.25?), drill the hole to correct size as specified in the repair kit, tap it with helicoil tap, insert the helicoil, trim the helicoil and you're done.
    Senior Member gene03079's Avatar
    Aug 2008
    Bluffton SC USA.
    Gearing you can run 16/38 then as you get the hang of turn 3 change to 16/36
    Gene
    USCRA 521
    May 2011
    Attleboro, MA, USA.
    Thanks. Do you know what other bikes have compatible sprockets? I am finding a ton for CB350s but not having much luck for the 175.. Thanks again
    Aug 2008
    Bluffton SC USA.
    The guys at Rebel Gears can send you any size you need. I started using Rebel after Sprocket Specialists dropped the ball
    http://www.rebelgears.com/images/343...12_Catalog.pdf
    Gene
    USCRA 521
    Senior Member Teazer's Avatar
    Mar 2010
    , IL, .
    What happened to Sprocket Specialists? I haven't needed sprockets for awhile so I wasn't aware there was an issue.
    Aug 2008
    Bluffton SC USA.
    My last order with Sprocket Specialists was a nightmare. They took forever sending the sprocket out for my MT125R. When it arrived it was not the correct dimension and would not fit. After calls and emails they agreed to send a replacement. The replacement never came. Overall nasty customer service people and crap service. I will not use them again.
    I called the guy at Rebel Gears explaining I need a sprocket fast. He knew what I needed, made and shipped the sprocket the next morning. They even sent it overnight just to be sure everything was OK before the race. Way better service and half the cost of the other guys.
    Gene
    USCRA 521
    Mar 2010
    , IL, .
    Thanks, I'll try them next time I need sprockets
    Nov 2008
    Got a link for Rebel Gears?
    Aug 2008
    Bluffton SC USA.
    Gene
    USCRA 521
  1. CB350 Racer Build questions
    By Ron Bloker in forum Vintage Motorcycle Racing
    Last Post: 08-31-2012, 04:45 PM
  2. CB350 race build questions
    By Livetoskate in forum Vintage Motorcycle Racing
    Last Post: 08-21-2012, 05:59 PM
  3. CL175 Tech Questions
    By sambo in forum Technical
    Last Post: 10-11-2011, 08:44 PM
  4. cb 160 build questions .
    By griff 73 in forum Project Builds
    Last Post: 07-20-2008, 11:56 AM
  5. cl175 build - carb issues
    By nixoid in forum Technical
    Last Post: 03-26-2008, 11:50 PM
71 cl175 gears
cb175+race engine
cl175 exhaust
cl175 race build
cl175 racing
cl175 velocity stacks
how much fork oil cl175
pods for cl175
what happened to sprocket specialists
