Is there an Easy way? - Page 2
This is a discussion on Is there an Easy way? within the Technical forums, part of the Caferacer.net Forums category; quote: Originally posted by Tonnystark Do trust that I am using machines where ever possible ( multi wheels and dremels), yet the lines are a ...
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    FR
    FR is offline
    Senior Member FR's Avatar
    Nov 2004
    Essex Jct, VT, USA.
    quote:Originally posted by Tonnystark
    Do trust that I am using machines where ever possible ( multi wheels and dremels), yet the lines are a bitch as you canot deviate the direction in anyway or it will show (thus by hand, slow and safe..) 1500 wet or dry leaves a nice satin looking reflection and desired fine line's after a light polish..Figure to polish out the large cover clean and blemish free, then make specific shaped sanding blocks to get into those crany area's...(thinking this how yami had to do it to get it done as well as they did...)
    I'd bead blast if possible.
    FR
  2. #12
    FR
    FR is offline
    Nov 2004
    Essex Jct, VT, USA.
    FR
  3. #13
    Senior Member nic579's Avatar
    May 2010
    May 2010
  6. #15
    Senior Member Tonnystark's Avatar
    Jun 2012
    , florida, USA.
    IMHO bead blast would be way too abrasive!!!!...As I am trying to keep or replicate the original machined surfaces and textures ,anythiung that would 'frost' would damage further what Yamaha intended.. I did roll #2 steel wool into 1/4 inch balls and used various sizes of hard wood dowel to apply pressure to clean the old clear off.. then using a hole punch, popped out a bunch of "dot's" from 1000 grit wet or dry and then using the same wood dowels, duplicated the proper directional scratches into the clutch side cover's tight nooks and sharp corners...
    Industrial and gun bore cleaning brushes are being used thru out this effort, primarily all being brass brushes with plenty of spray oil, works real well ..
    3m' should make Scotch bright Q-tips on wooden dowels so I dont have to make my own..
    78' SR500
    64' YG1S
    15' XT250
  7. #16
    Jun 2012
    , florida, USA.
    78' SR500
    64' YG1S
    15' XT250
  8. #17
    ....I did roll #2 steel wool into 1/4 inch balls and used various sizes of hard wood dowel to apply pressure to clean the old clear off.. then using a hole punch, popped out a bunch of "dot's" from 1000 grit wet or dry and then using the same wood dowels, duplicated the proper directional scratches into the clutch side cover's tight nooks and sharp corners...
    Dude - you got too much time on your hands.
  9. #18
  10. #19
    Jun 2012
    , florida, USA.
    HA,HA,HA,HA Being single I can do what and when I want.. bike is in the spare bedroom , on a stand sitting on a painting tarp ..I have wanted to redo this for a while now!
    78' SR500
    64' YG1S
    15' XT250
  11. #20
    Jun 2012
    , florida, USA.
    78' SR500
    64' YG1S
    15' XT250
  1. Clubman bars not so easy...
    By CL175guy in forum Technical
    Last Post: 06-26-2012, 01:15 AM
  2. Is there any easy way to shorten Cables?
    By JackC in forum Technical
    Last Post: 07-25-2011, 09:18 AM
  3. Sometimes its just to easy...
    By oneworden in forum General
    Last Post: 07-30-2010, 07:09 PM
  4. ok Easy now Newbie here............
    By gr8lite in forum General
    Last Post: 06-03-2008, 10:39 AM
  5. Why is this sh*t never as easy as you think?
    By robertob in forum Technical
    Last Post: 11-01-2006, 04:33 PM
sr500 redo
