cb550 has 78+ cb750f forks, why?
This is a discussion on cb550 has 78+ cb750f forks, why? within the Technical forums, part of the Caferacer.net Forums category; the previous owner of my 76 cb550f put a 78 or later cb750f front end on it... and i was curious as to what benefit ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Member jason41987's Avatar
    Jun 2012
    , , USA.
    the previous owner of my 76 cb550f put a 78 or later cb750f front end on it... and i was curious as to what benefit that would offer over the standard forks?, what would be gained from it, and what is lost from it?
    Senior Member jaguar's Avatar
    Dec 2005
    Albany NY
    Dual disc brakes were gained
    Spoked wheel was lost
    I am Derby\'s Bitch
    Senior Member Tonnystark's Avatar
    Jun 2012
    , florida, USA.
    different rate of compression on the front suspension more than likely also..
    78' SR500
    64' YG1S
    15' XT250
    Nov 2008
    750 forks are longer and stiffer springs than 550 ones.
    I replaced tubes and springs on my 550 plus used 750 rear shocks.
    The extra ground clearance came in real handy
    Jun 2012
    , , USA.
    hmm, I'd prefer to keep my spoke wheels, currently it has a spoke wheel installed and no front brakes, I'm guessing there would be a conflict between the brakes that go with these forks and the rotor on the wheel itself...
    so looking to keep the spoke wheels, what would be the best forks I can use on a 76 550f?
    Nov 2008
    It would be easier to modify what you have.
    May need some new axle spacers and probably spacers under rotor/hub mount to get discs in correct position
    With some though and engineering, almost any fork can be fitted to almost any bike
    Jun 2012
    , , USA.
    are there any benefits to these 750F forks besides dual rotors? if not then Ill keep the option of switching them open, but if I were to change them I'd like to go with inverted forks, and for that a modern sport bike front end would be needed
    are there any inverted forks out there that wouldn't be too difficult to switch to, allows me to reuse my original speedometer, with a compatible hub that would allow me to have a spoke front wheel?
    Nov 2008
    All inverted forks are going to be more difficult to fit than 'conventional' and will require some machining of new spacers at the very least
    Most modern inverted forks will also be too short (unless off a custom/cruiser)
    Jun 2012
    , , USA.
    not true, i see gsxr inverted forks used on these bikes often enough without modification to the forks themselves
    Sep 2010
    Boston, Georgia, USA.
    then it sounds like gsxr forks are what you are looking for
  1. '78 cb750f-cbr?
    By oldhondacafe in forum Project Builds
    Last Post: 12-02-2011, 05:35 PM
  2. cb360 -> cb550/650 forks question
    By kerosene in forum Technical
    Last Post: 06-05-2011, 11:30 PM
  3. Replies: 24
    Last Post: 12-14-2010, 02:50 PM
  4. Wanted: CB750F forks
    By xxwelderxx in forum Wanted
    Last Post: 01-06-2010, 12:35 AM
  5. CB550 Forks and Triple Tree
    By keith99 in forum Wanted
    Last Post: 06-30-2009, 05:46 PM
cb 750 front end preload
cb550 fork swap hub
cb550 front brake upgrade options
cb550gsxrfork
cb750f forks
gsxr forks cafe racer honda 550 cb
honda cb gsxr fork swap advantages
nighthawk 750 fork swap
what forls will swap on my 1992 nighthawk 250
