cb360 lean/rich issue - Page 2
This is a discussion on cb360 lean/rich issue within the Technical forums, part of the Caferacer.net Forums category; Engine is stock, what about exhaust system, air boxes and carbs?...
Results 11 to 20 of 23
  1. #11
    Nov 2008
  2. #12
    Junior Member gearhed31's Avatar
    Sep 2012
    utica, ny
    air box, no air cleaner (for now), exhaust is some pipes i found and modified to fit, came from a 80s suzuki 650 4cyl, so less exhaust resistance. carbs are stock as far as i know, they have 110 jets i believe
    i found the answer to all life\'s problems- HIT IT WITH A HAMMER
  3. #13
    Mar 2006
    south Orange County, CA, USA.
    quote:Originally posted by crazypj
    They do that with pods
    If you jet for top end, it goes super rich at transition from primary to secondary main jet (when slide starts to lift)
    If you don't re-jet, it runs fine to 4~4.5k then starts to go lean and probably won't go over 7k
    Pay attention here, gearhed. Crazy PJ knows how to adjust/correct for pods on a CB360, and he just might tell you how it's done.
    Sep 2012
    utica, ny
    im fine with the 7k, as long as it runs good up to there. how should i go about adjusting it
  6. #15
    May 2006
    Detroit-ish, MI, USA.
    quote:Originally posted by gearhed31
    im fine with the 7k... how should i go about adjusting it
    Put an air filters in it, and some proper pipes on it. At 7,000RPM, you're losing out on half the "usable" powerband.
  7. #16
    Sep 2012
    utica, ny
    found the issue, blown out diaframs in both carbs, slides werent moving at all. was adjusted rich trying to compensate for lack of flow. fixed diaframs, readjusted carbs, runs like a raped ape. thanks for the help
  8. #17
    May 2006
    Please, enlighten us as to how you fixed diaphragms.
  9. #18
    May 2006
    How old are you? (just read bio).
  10. #19
    Sep 2012
    utica, ny
    filled the hole with rtv...works for now... getting replacements
  11. #20
    Sep 2012
    utica, ny
    im old enough to gamble, ride a motorcycle, and be in college, not old enough to drink legally (although that has never stopped me)... why do you want to know
  1. CB360 Carb issue
    By mega4ce in forum Technical
    Last Post: 02-10-2011, 03:03 PM
  2. running rich on one side...
    By TheGreg in forum Technical
    Last Post: 01-26-2011, 10:54 PM
  3. CB125S runs rich
    By Thickshady in forum Technical
    Last Post: 06-23-2010, 02:38 PM
  4. IF I were a rich man!
    By Pete Casper in forum Bikes For Sale
    Last Post: 05-03-2008, 11:15 PM
  5. one cylinder rich one fine
    Last Post: 03-26-2008, 01:26 AM
black plugs cb360
cb 360 needle shim
cb 360 running lean
cb360 fouling
cb360 running rich
cb360 running rich with pods
cb360 sputtering
honda cb360 fouling plugs
how to lean out cb360
