cb360 lean/rich issue
This is a discussion on cb360 lean/rich issue within the Technical forums, part of the Caferacer.net Forums category; on my cb360 engine, its fouling plugs out, so that should mean rich, right? but it also runs better with the choke on, which should ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Junior Member gearhed31's Avatar
    Sep 2012
    utica, ny
    on my cb360 engine, its fouling plugs out, so that should mean rich, right? but it also runs better with the choke on, which should mean lean, right? does this make any sense to anyone, and does anyone know what the issue is?
    i found the answer to all life\'s problems- HIT IT WITH A HAMMER
    p1j
    p1j is offline
    Senior Member p1j's Avatar
    ft. collins, colorado, Spain.
    maybe this cb it has bad rings to foul the plugs and a main jet with a part obstruction make the lean condition.
    -p1j
    p1j
    p1j is offline
    -p1j
    Nov 2008
    They do that with pods
    If you jet for top end, it goes super rich at transition from primary to secondary main jet (when slide starts to lift)
    If you don't re-jet, it runs fine to 4~4.5k then starts to go lean and probably won't go over 7k
    Nov 2008
    Sep 2012
    utica, ny
    it only reaches about 3.5-4k rpm before it breaks up and sputters. runs fine at half throttle, once you go full it loses al power
    Sep 2012
    utica, ny
    Nov 2008
    You'll have to list the 'modifications' you've done
    Did you shim needles?
    Nov 2008
    Sep 2012
    utica, ny
    the engine is stock, sat for a long time.
  1. CB360 Carb issue
    By mega4ce in forum Technical
    Last Post: 02-10-2011, 02:03 PM
  2. running rich on one side...
    By TheGreg in forum Technical
    Last Post: 01-26-2011, 09:54 PM
  3. CB125S runs rich
    By Thickshady in forum Technical
    Last Post: 06-23-2010, 01:38 PM
  4. IF I were a rich man!
    By Pete Casper in forum Bikes For Sale
    Last Post: 05-03-2008, 10:15 PM
  5. one cylinder rich one fine
    Last Post: 03-26-2008, 12:26 AM
black plugs cb360
cb 360 needle shim
cb 360 running lean
cb360 fouling
cb360 running rich
cb360 running rich with pods
cb360 sputtering
honda cb360 fouling plugs
how to lean out cb360
